Sponsored by: Real Truck
front hitch
Old Nov 25, 2007 | 11:37 PM
pushingxthexedge's Avatar
pushingxthexedge
front hitch
I have a receiver hitch on the front of my 99 f 350 and the hole in it is to far back for any of my drop hitches has any one else had this problem with a front hitch. It was installed by the owner before me and he used it for a wench set up.
Old Nov 25, 2007 | 11:43 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
They make extensions that you can slide in.
3/4 of the way down the page:
http://www.hitchcorner.com/trailer-h...ccessories.htm
Old Nov 25, 2007 | 11:50 PM
pushingxthexedge
thats not quite what i ment but thanks for the info. i'll clarify it a little bit more the holes don't line up on the receiver and the hitch it self. the hitch as in as far as i can put it and the hole on the receiver is still to far back.
Old Nov 26, 2007 | 05:46 AM
JOE-M's Avatar
JOE-M
No I've never heard of this before. Maybe take the hitch off and drill another hole. Or you could take one insert and re-drill it to fit your receiver.
Joe
Old Nov 26, 2007 | 09:50 AM
Sebs's Avatar
Sebs
That "wench" thing sounds a little kinky . . .
Old Nov 27, 2007 | 12:15 AM
texan2004's Avatar
texan2004
I actually have the opposite problem with mine. I have a warn front hitch. If I use a normal stinger, it hits a bolt that goes through the middle of the receiver. I have to use a stuby stinger to use the front hitch. You would think that they would have standardized these hitches but they haven't. I'd look for a longer stinger. They are out there.
Old Nov 27, 2007 | 10:10 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Maybe it was custom (homemade) for his application. Drill another hole in it.
Old Nov 27, 2007 | 10:57 PM
shockwave6's Avatar
shockwave6
Sure does but this is even worse!
... does it work in the back correctly? If so I would just drill another hole.
Old Nov 29, 2007 | 12:24 AM
pushingxthexedge
The hitches them selves are fine they work normaly in the back but not in the front and i don't want to risk messing up the hitches to make them work on the front. some one suggusted just cutting off the end of the hitch to make it slid in till the holes line up. Does that sound like a good idea, i don't want to screw up the hitch.
Old Nov 29, 2007 | 08:18 AM
texan2004's Avatar
texan2004
They make short stingers. Go buy one. They don't cost much.
Old Nov 29, 2007 | 10:26 AM
Momorris's Avatar
Momorris
I had a warn front reciever on my old truck and there was maybe 2-3 inches from the pin hole to the front. Considering the front hitch is just for moving trailers and will never be used on the road I think you will be just cutting the a bit of the end of and this should be easier than drilling a new hole.
quincyj34
20
Feb 11, 2015 08:00 PM
Rocketattack
Jul 25, 2013 09:48 PM
MarkysExpy
Mar 23, 2006 01:00 PM
mike357
Jun 17, 2003 04:52 PM
