How fast should a starter turn
Old Jan 20, 2005 | 12:36 PM
Bromideford's Avatar
Bromideford
ive got an 83 ford 100 it runs great when it starts, When i turn the key it will turn over but not very fast, sounds like it has a dead battery, I can jump it off and it will start good, I took the starter off and hooked a pair of jumper cables to it to see it spin, It spins but slow, I was wondering have fast should it turn. Any help would be greatly appriciated
Old Jan 20, 2005 | 02:40 PM
Beast12's Avatar
Beast12
If you think it is spinning too slow then it probably is. It could also be your battery. If the starter is really old then maybe just replace it?
-Matt
P.S. Welcome to FTE!
Old Jan 20, 2005 | 04:10 PM
mustange70's Avatar
mustange70
It could be just wore out cause as you said it spins slow on the bench test, you could replace the brushes (thats kinda of a pita), but i think its just generally wore out.
Old Jan 20, 2005 | 05:57 PM
DT 466Man's Avatar
DT 466Man
do the batt cables get hot?
Old Jan 20, 2005 | 08:18 PM
srercrcr's Avatar
srercrcr
The counterman at AutoZone showed me where the later 300s have a better starter than my 83 came with. It fits fine, spins real strong.
Old Jan 20, 2005 | 10:51 PM
dilbone56's Avatar
dilbone56
I just went through the same thing with my 82 302. I had just overhauled the engine, and when I went to start it, it would barely turn over and only turn over a few times before my battery died. When I put it on a charger/starter, it would turn over faster, but still not like it should. I replaced the starter tonight, and it turned over perfectly. If your starter is struggling to start it will drain your battery in a hurry and give you the impression that you have a bad battery. I'd check the battery out at autozone first (because it's free), then I'd go with a new starter if the battery checks out good. Good luck.
Old Jan 21, 2005 | 01:49 PM
Bromideford
im certain it aint the battery because i took it off and put the battery to my other truck on it and it does the same thing. Im picking up a new starter this evening so maybee it will fix the problem
thanks for all the help
Old Jan 21, 2005 | 03:50 PM
mustange70's Avatar
mustange70
do a bench test on the new starter to compare the difference in speed between the 2, this way if the starter isn't bad then you don't have the extra trouble of pulling the starter out again.
V10man
Nov 14, 2012 04:50 PM
jdneal88
Apr 21, 2011 08:03 AM
shan69743
19
Sep 25, 2009 05:24 AM
Rio_Grande
Jan 3, 2008 06:42 PM
jgurland
13
Apr 5, 2006 09:22 AM
