Sponsored by: Real Truck
Starter not spinning fast enough?
Old Jan 2, 2008 | 10:21 PM
Rio_Grande's Avatar
Rio_Grande
I have had problems with my 99 starting on cold days. This morning it happened again. After finally getting it running a 6 hour adventure in which I found that the heater wire had a short in it, the glow plug relay and glow plugs tested out and the heater shows continuity. The starter turns slow when the truck is cold. I had just had the batteried replaced under waranty due to this issue. I took it to my local dealer who has the only mechanic I trust my truck with. After doing pretty much what I had done but more professionaly he determined that the problem was likely the starter not spinning up fast enough when it was cold. I went ahead and got a high torque reduction drive starter and it screams to a start now.
Does any of this sound reasonable? What else would cause it to not start on cold mornings?
Old Jan 3, 2008 | 03:44 AM
Monsta's Avatar
Monsta
Sit. Stay.
Sounds reasonable enough. You say it start a lot better now?
Not sure how many miles you got on your truck but a 99...that starter had turned over that PSD many, many times.
Old Jan 3, 2008 | 07:31 AM
Rio_Grande's Avatar
Rio_Grande
I see your point, 160,000 miles and alot of short trips, You are probably right.
Jeff
Old Jan 3, 2008 | 11:42 AM
dyhrdford's Avatar
dyhrdford
I am currently having the same exact problems with my 01 7.3L. It starts like a champ on days 30 or above, but when its single digits or just above that, it is REALLY slow to crank. I replaced the batteries, (original batteries in an 01) and no difference. Last night, it was 8 degrees, and it started like a champ too. It does it when it wants to I guess????? I am pulling my hair out!! You say you got a starter and its working fine now? If you dont mind me asking, how much did you pay, and where did you get it? Aaron
Old Jan 3, 2008 | 02:12 PM
Rio_Grande's Avatar
Rio_Grande
It was a gear reductin and cost just over 200 installed. It came from Struckman Ford in Osgood IN. Justin there really knows his stuff and has done almost all the repair work That I haven't done to my ford. I didn't shop around as we needed the truck up and running fast. They have always treated me right, Sometimes even better than that.
Old Jan 3, 2008 | 06:42 PM
nitrogen's Avatar
nitrogen
the only parts that generally wear are the bushings and brushes. you can get a kit with them for prob no more than 20% of another starter, now if your starter has developed a dead spot that is another issue, but it can also be repaired as good as new.the dead spot is caused by overheating which weakens the solder where the commutater ribbons attach to the commutater. set the shaft in a metal lathe on slow speed and cover the whole brush surface of the comm with a high temp silver solder, ( use a rosebud on an oxy acetyline to get enough heat) after it cools down use the lathe to trim down the excess solder. does it work?was shown to me by instructor at diesel mech college electrical was his specialty. other than that while your in there put on a new solenoid as the contacts
do wear and will increase in resistance which gives your starter less to work with
Firefighter 1406
56
Jan 5, 2017 07:21 PM
Johnny Bravo 45
Dec 1, 2015 06:38 AM
Nobody39
Nov 25, 2015 03:26 PM
dburke8088
Jan 7, 2014 11:21 AM
GonzoCSU
Feb 3, 2010 08:54 AM
