98 Exp Blinking Overdrive Light
Old Jan 19, 2005 | 12:15 PM
aviatorone's Avatar
aviatorone
I have a 98 Exp 4wd XLT, the overdrive light on the column started to blink. As its blinking the transmittion is either slipping or snatches from gear to gear. If I shut the truck off and restart it, the light will go off and the vehicle runs like it should. Then 10 min later the problem will return. Any ideas would be greatly appreciated. Thx.
p.s. I just crossed over 140,000 miles....
Old Jan 20, 2005 | 01:04 PM
vjstangelo's Avatar
vjstangelo
This happenned to my '99 Expy. I was told by others on this thread that this is a "check engine" light for the transmission. When the light blinks, the transmission goes into "safe" mode where the shifting is "jerky". Your best hope is to bring to a good transmission service place before more damage is done. In my case it was some sort of shift valve that cost about $300 to fix (ford dealer). No problems since.
Old Jan 20, 2005 | 02:30 PM
marlinmike's Avatar
marlinmike
Mine came on in a 99, was the wiring within the tranny, $300 range. Also had it flushed while there.
Old Jan 21, 2005 | 09:28 AM
aviatorone's Avatar
aviatorone
FYI... I took it to AutoZone last night to see if an error code would come up. No code came up. (didn't figure it would). Guess I'll have to swing by Ford now.... Thx!
Old Jan 21, 2005 | 11:02 AM
PaulC's Avatar
PaulC
I'm almost positive that OBD II readers won't pick up transmission error codes.
Old Jan 29, 2005 | 09:23 AM
aviatorone's Avatar
aviatorone
Just got it back. The T/C was coming apart, it thru metal shavings all thru the trans. Got a Reman from Ford, total cost was $2,800. (Ford didn't do the work)
patsalters
Sep 11, 2013 09:43 AM
allingeneral
Aug 17, 2013 03:50 PM
plowguy
Jan 6, 2006 06:23 AM
nothingbutford
Sep 4, 2001 12:08 AM
woodyropes
Jul 14, 2001 01:35 PM
