ABS light
Old Oct 6, 2012 | 06:00 PM
Diesel_Brad's Avatar
Diesel_Brad
ABS light
I have a ABS light on on my 97. My snap on scanner does not go into the abs. How do I pull codes?
Old Oct 6, 2012 | 06:35 PM
Puddy's Avatar
Puddy
Hope this help brad
https://www.ford-trucks.com/forums/3...7-f-250hd.html
Old Oct 6, 2012 | 06:45 PM
Diesel_Brad
Any idea where the RABS connector is?
Old Oct 6, 2012 | 07:14 PM
danr1's Avatar
danr1
Safe to assume its in the same place as say 95-96 models?
Slightly left of center line of glove box door, just above the lower edge of the dash.
Old Oct 7, 2012 | 07:16 AM
Diesel_Brad
There is a single wire connector there says PSOM on it
Old Oct 7, 2012 | 07:50 AM
Lazy K's Avatar
Lazy K
Ford Truck Enthusiasts Forums - View Single Post - abs question Some info here may help, although I believe his was a pre `92 truck so diagnostic connector was not behind the glovebox.
I think you should be looking for a black wire with an orange stripe plugged into a black wire.
Old Oct 7, 2012 | 08:15 AM
danr1's Avatar
danr1
Yea that is there too in the previous model years, be just to the left of that held in place by a plastic push pin. Is a chance they moved it for that model year but I don't know, just doesn't seem likely they would have reason too.
Is the rabs module in the same place in the 97 model? still mounted up high and behind the glove box? If so kinda suggest that diagnostic connector still be in the same place yet.
Old Oct 7, 2012 | 08:23 AM
bashby's Avatar
bashby
Brad, did you find the wire to check codes? I've also got an abs light on my 92 and you kinda inspired me to look into it. I did find a single black/orange wire behind the glovebox, but grounding it didnt make the light flash.
Old Oct 7, 2012 | 08:37 AM
danr1's Avatar
danr1
Was that wire connected to another wire? you had to unplug the two from each other first?
I had to get kinda aggressive to get mine to spew forth the code, key on grounding the wire repeatedly few time before it'd start flashing.
I used the center dash support bolt.
Warning as to fact blow a fuse if ground out wrong matting half suggests its power to the rabs module? my book shows the connector as a dead end in the wiring diagram same time!
My ABS lights been on since a cab swap so I just did the same thing too, trigger the test to narrow down why.
Old Oct 7, 2012 | 08:44 AM
bashby's Avatar
bashby
No it wasnt connected to anything else. I've been researching it and found that 87-92 has the same test plug, they probably changed it by 97. I'm pretty sure I got the right wire to ground. Her's a decent bit of info I found.
How to: Retrieve ABS trouble codes - Ford F150 Forum - Community of Ford Truck Fans
Didnt mean to hijack your thread, Brad.
Old Oct 7, 2012 | 08:53 AM
danr1's Avatar
danr1
Yup shows it the same for my 94 however the connector is plugged into a matting half, I believe its a black wire.
My book lumps 92 and up in the same group RABS II, picture suggest that in link too. Earlier years its over on the drivers side RABS I.
Never too sure where the changing point is using a Haynes manual though.
And myself I don't see your posts as any kinda "thread hijack" not at all, all info can only help him find it in that one. "97" who knows what they might have done! OBS so hopefully its in the same place as year before it.
Following in cab harness back from RABS module, that would......should.... eventually bring him to it!
Old Oct 7, 2012 | 08:59 AM
Diesel_Brad
I will have to get back under the dash and check. I did swap out the RABS module for a DRW one since I am making it a dually(behind glove box)
I have to do some mirror wiring today if the rain holds off, i'll look then
93 mix 'n match
1997 - 2003 F150
May 6, 2010 10:44 PM
speedyejl
Apr 21, 2010 02:38 PM
ranger61878
1983 - 2012 Ranger & B-Series
17
Jul 25, 2006 05:11 PM
TAMC
1997 - 2003 F150
Nov 25, 2003 09:27 AM
