Wiring Question
Old Jan 18, 2005 | 05:27 PM
y2klarry's Avatar
y2klarry
Question Wiring Question
First I would like to say that I am a mechanic however I do not have a lot of access to ford manuals. Here is my trouble. I hooked up a remote start unit on my 01 f-150 Screw. Now when I have the ignition on with the key in the ignition and I put the truck in gear, drive or reverse my radio cuts out. When I return the trans to park or neutral the radio comes back on, however the 4x4 lamp illuminates for a second. I have tested all the wiring and it appears to be correct. This even occurs when I have the remote starts wiring harness for door locks and security disconnected. So all that is hooked up is the power, acc, ground, tach, and hood pin. Any thoughts would be appreciated. The outfit I bought it from is not keen on trying to help me out. They want me to bring it in so they can "reinstall it correctly". Man is it frusturating. Thanks again.
Old Jan 20, 2005 | 07:34 PM
y2klarry's Avatar
y2klarry
It would seem that I have apoor ground within the remote start unit. After extensive testing it started to work.
Bryan Hagan
Dec 19, 2015 07:50 PM
Rainmaker68
Jan 14, 2013 04:59 AM
WyattSmith529
1978 - 1996 Big Bronco
Mar 25, 2011 06:30 PM
widebody95
Jan 6, 2009 01:02 PM
keego rebel
Mar 27, 2006 11:45 PM
