multiple problems
Old Jan 20, 2005 | 07:11 PM
sthrnredneck's Avatar
sthrnredneck
multiple problems
Ok yall, the first started about 8 months ago the wipers only work on high. When i installed an aftermarket radio the dash dimmer screwed up now dash light work only on full bright. One reverse light has never worked but now neither do and bulbs are fine. Also my turn signals quit workin this week. Hazard flasher work all around but no light inside or out when turn signal is on. No sound either. Replaced flasher already. Any help on any problem would be greatly appreciated.
Old Jan 20, 2005 | 09:36 PM
Mil1ion's Avatar
Mil1ion
Which truck is this ?
Are you sure you checked/replaced the correct flasher ?
Old Jan 20, 2005 | 11:01 PM
Franklin2's Avatar
Franklin2
Yes, what are we working on?
Old Jan 21, 2005 | 09:36 AM
sthrnredneck
1990 F150. Sorry i thought i put that or it was in my signature one. I replaced the flasher in the fuse box. If there another one please tell me where it is.
Old Jan 21, 2005 | 01:55 PM
Franklin2's Avatar
Franklin2
You might fix the wiper problem and the turnsignal problem with a new multi-function switch. It's mounted in the steering column, and is what you would normally think of being the turnsignal switch. But it has many other functions in it too.
