Headlight Adjustment
Old Jan 18, 2005 | 07:35 AM
The67Beast's Avatar
The67Beast
Here's a hard question; How do you adjust the headlights on a 67 thru 72 after you have had it torn down for a rebuild? I am sure there is some factory specs on how it should be done in order for the beams to be legal. Most likely I'll have to park the truck, at some interval like 25-30 feet, on level ground facing the side of a building. Then measure up for the high beam and low beam. I am not sure. Anyone else want to take a crack at this????
Old Jan 18, 2005 | 07:45 AM
4Cammer72's Avatar
4Cammer72
some of the full service stations used to have a headlight alignment tool that hooked to the light and then you just lined up the crosshairs with the bubble and you were done. maybe one would still have one.
Old Jan 18, 2005 | 12:01 PM
cleanLX's Avatar
cleanLX
pull your truck up to a wall.
mark the centers of your beams on the wall with approx 8" large crosshairs.
back up 25'.
align the hot spots center'd on the vertical crosshair, and fully below the horizontal crosshair.
Rusty_S
Nov 9, 2014 07:59 AM
V10man
Aug 22, 2012 03:47 PM
Rattler60
Sep 30, 2010 10:16 PM
cabo169
1983 - 2012 Ranger & B-Series
Mar 28, 2008 02:51 PM
