99 Ranger headlamp adjustment?
Old Mar 27, 2008 | 07:03 PM
cabo169's Avatar
cabo169
Guys, help me out here please. How do you adjust the headlights to lower the beam? My truck sits on a 3" body lift, 33 inch BFG's and I am shooting owls. I do not see any "typical" adjustment screw.
Old Mar 27, 2008 | 11:25 PM
Bikeitswift's Avatar
Bikeitswift
Did you remove the little plastic "lid" over the lights (when your lift the hood)...the ones you have to remove to change bulbs..? I recall some adjustment ***** under that, but do not remember if up/down is in there, or just left/right.
Old Mar 28, 2008 | 06:48 AM
cabo169's Avatar
cabo169
I had looked at removing the lens cover, but was not quite sure if that was the route to go. Thanks for the info. I will try that today.
Old Mar 28, 2008 | 08:58 AM
Bikeitswift
Not the lens cover. On my '02, when you lift the hood, there is a little black plastic cover over each light that is held on my two screws. Removing that exposes adjusting **** (s).
Old Mar 28, 2008 | 12:47 PM
cabo169's Avatar
cabo169
Ah yes, I see. Thanks again!
Old Mar 28, 2008 | 02:51 PM
cabo169's Avatar
cabo169
Ok, I can invision what you are talking about, but it does not apply to my truck. The lights are mounted into the plastic facia, I do not have those covers as yours. As far as I can see, I have the light fixture, 2 bolts with back clips one is accessible the other is within the fixture not accessible. Then there is the bulb housing that fits into the back of the fixture. These are the only components or fasteners around the light. I even took the grill off to see if there was anything else holding the light in, but, nothing. The only way to access the bulb housing is through the engine bay and even removing the battrery and the top to the air filter so I could get a better look didn't help me find any adjusters. I am baffled about now and am thinking they do not have adjusters. Oh well, I pity the owls.
gthbryce
30
May 24, 2026 12:12 AM
cornking
Dec 7, 2011 07:43 PM
reifwj
29
Apr 22, 2008 09:13 AM
sergeant2
May 23, 2005 08:51 PM
ford390gashog
Nov 1, 2004 09:27 PM
