Hella headlight adjustment
Old Nov 7, 2014 | 09:22 AM
Rusty_S's Avatar
Rusty_S
I finally got to try my new headlights out with the s ilverstar ultra on a dark road.
I wanted to ask how do you align the beam pattern for the E series housings?
Low beam seems fine but switching to high beam the distinct line of light is up in the trees and the road is dark not even a glimmer from thr road reflectors. The low beam works fine as it lights street signs up high fine till you get to within 20-30 feet then it doesn't glow anymore.
I am thinking I need to tilt my housings down but not sure if there's any special alignment pattern for the E style housings or if I just do it like they are dot housings.
Old Nov 7, 2014 | 03:52 PM
firegod33's Avatar
firegod33
Aim as normal. Are these lights not DOT compliant?
Old Nov 7, 2014 | 09:42 PM
82F100SWB's Avatar
82F100SWB
http://www.danielsternlighting.com/tech/aim/aim.html
That is a pretty good explination of the procedure.
I used to just keep a screwdriver in the truck and adjust as needed until I got them just right.
Old Nov 8, 2014 | 02:24 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
^^^ X2.
I've linked Stern's page(s) for Rusty too many times to remember.
All you have to do is find a level lot and the broad side of a barn or warehouse.
There's no way the high beams should be pointing any higher than the headlight actually is above the pavement.
Old Nov 8, 2014 | 10:28 PM
Rusty_S's Avatar
Rusty_S
I was at work when I made the post, it was slow to the point that I was messing with the truck and was going to try adjusting them at the shop before leaving.
I didnt have the website saved in my phone but I did a search for the headlight alignment for the E code lights and I found the Daniel`s site and read and took notes.
I did adjust the alignment tonight but I only tilted the lights down by turning the adjustment screw out 4 full turns on both sides. It appears that it is close enough till I can get a flat area where I can park the truck 25' away and do the alignment properly. Before on low beams the stop sign at the end of the street was lit up like it was on highbeams. Now with the lights dipped 4 full turns, the stop sign has a faint light glow on low and a very bright glow on highbeams. It looks like the highbeams might be a tad high still but it appears they are throwing more light on the road than before. Will try them out after work on Monday and see if I need to go another turn or two out.
Old Nov 8, 2014 | 10:33 PM
Rusty_S's Avatar
Rusty_S
No they are not DOT/SAE compliant, they are ECE Compliant.
From the reading I have done, DOT/SAE compliant lights have been the same requirements since the 1950's. ECE how ever are different in the sense that they are not allowed to throw a lot of light up high as signs where ECE lights are legal has to either be illuminated or highly reflective that glow with very little light.
This is why street signs have been a problem for me reading them as the signs require quite a bit of light to cause them to illuminate. Not a problem for me because I can rest assured that once I get these lights properly aligned I wont be blinding people unlike every other car on the road because of how much light they throw up and out into oncoming traffic.
Old Nov 9, 2014 | 07:59 AM
Gary Lewis's Avatar
Gary Lewis
This is an interesting read about the differences between DOT and ECE lighting systems.
Bite N Hold
Sep 18, 2016 06:48 PM
351Cleveland C4
Dec 7, 2014 10:52 PM
Ryno F-150
16
Jun 19, 2011 09:36 AM
unibody62
Dec 15, 2009 12:02 PM
Dj300ford
Aerostar
Dec 13, 2003 02:17 AM
