odometer rollback
Old Jan 15, 2005 | 02:07 PM
ford390gashog's Avatar
ford390gashog
Question odometer rollback
ok i brought my 03 expy in for electrical work they had to replace a module which they thought was causing the short well that did not fix it when i brought my expy in fri it had 19,506 on the odometer and it cam e out with 19,075 how did they do this someone telll me how they did this i want to make sure i know when i talk to them monday
Old Jan 15, 2005 | 03:08 PM
triton_2002's Avatar
triton_2002
What module did they change?
Old Jan 15, 2005 | 04:08 PM
ford390gashog
they said they needed to replace some module because my dash lights kept burning up why would the roll the odometer back
Old Jan 15, 2005 | 04:30 PM
triton_2002
As far as I know, the milage is stored in the odometer display. For example, if you swap a Ford guage cluster (with the odometer display) from a truck with 10,000 miles and put it in a truck with 100,000, the truck with 100,000 miles would now appear to have 10,000. If this was done by the dealer, then they would have to order a guage cluster with the proper milage programed into it.
Maybe some of the light bars in the odometer display are burned out and you're misreading it? Sounds like a wierd problem. Are you really sure you just didn't make mistake reading the odometer?
Old Jan 15, 2005 | 05:15 PM
ford390gashog
yeah i know its a weird problem i just changed the oil in it at 19,403 miles on the 10th the unit says 19,075 is it possible they can reprogram it this screw up really takes the cake now
Old Jan 15, 2005 | 05:32 PM
triton_2002
If the original problem was electrical, maybe that 3rd digit (00X000) on the display shorted out and it just reads 0?
Old Jan 15, 2005 | 06:39 PM
ford390gashog
that could be as i posted in another thread all the lights in my truck shorted out and melted the dimmer switch
Viny
18
Dec 27, 2016 11:47 AM
nick_ct_203
Sep 8, 2016 05:14 PM
patsoth
Dec 2, 2004 09:35 AM
carpentercb
Jun 5, 2003 05:30 PM
Acamar
Nov 7, 2002 12:00 PM
