Need help asap
Old Jan 14, 2005 | 07:09 PM
sdrowand's Avatar
sdrowand
Need help asap
First off I have a 1999 expedition E.B. 4.6L PRoblem is when the ignition switch is off and key removed,the climate control is blowing air out of defroster vents till battery goes dead. i am assuming it is some sort of relay malf. but what relay and where is it located . any hhelp would be greatly apprec.
Old Jan 15, 2005 | 08:21 PM
Glock 19's Avatar
Glock 19
I would agree it is a short. It could be the switch, a relay, or a chaffed wire somewhere. If you have an OHM meter you can start checking to see where the short is.
In the meantime until you can track it down. Pull the fuse of the climate control or pull the electrical connector going to the blower. This should stop the battery from draining
Glock
Jake45
Aug 24, 2009 07:56 AM
dbrugger
Jan 6, 2009 07:32 PM
jrouse
Dec 14, 2005 06:00 AM
KawiG5
Aug 10, 2004 05:30 PM
