Sponsored by: Real Truck
HELP with cold starting!
Old Jan 13, 2005 | 05:21 PM
fordracerman's Avatar
fordracerman
Cool HELP with cold starting!
Hello all! its been awhile and Happy New year to you all.I need to talk to someone with a ton of 7.3L experience. My truck has been getting harder and harder to start in the mornings.I found bad block heater and fixed it but still starts badly and this morning not at all.Granted it is -35 out but still need to drive lol.The only thing i can think of is that the glow plugs arent working. I checked and replaced the intake heater relay(was bad) and checked the glowplug relay seems fine.I also did a proper load test on batteries and they check out good.im a heavy duty mechanic so im not completely stupid but maybe im missing something short of taking it to ford $$$$ would like to fix it myself if i can.If anyone can help please let me know?Thanks for letting me vent lol.Nothin runs like a FORD!
P/S how hard are the glowplugs to change????
2001 F350 CC
complete 4'' exhaust
piller guages
edge evolution
bd performance tranny mods
35 '' tires w/ custom lift kit
ipc udgrade thats not installed yet lol
Old Jan 13, 2005 | 05:36 PM
Dealford's Avatar
Dealford
Glow plugs on a NA 7.3 are easy to change.
With the block heater plugged in & 8 new glow plugs, it should start OK. -35 will require you to cycle the glow plugs at least twice.
Plan "B".... If you don't care for using ether, open up the breather, lift it up and pour 1/2 ounce of gasoline right in it's air hole. I'd like to have a buck for every time I had to do that.
Of course the filters are all fresh.
AL.
Old Jan 13, 2005 | 05:42 PM
fordracerman
Thanks for the qick replay! Dont the wires for the glowplugs etc go through the valve cover somehow at least this is what i was told? Actually i tried either but it didnt work i didnt want to but thought id give it a go. But your saying to remove my Open air element and pour gas into it ill try but never thought of that ill try again! thanks again
Old Jan 13, 2005 | 05:51 PM
Dealford's Avatar
Dealford
When you didn't specify your truck was a PSD, I assumed it was NA. PSDs are a whole different can of worms.
Little, tiny, one second, baby shots of starting fluid will be OK when administered at the farthest opening of the air intake ductwork. A large shot is the type that will lock an engine up.
AL.
My Bad...Just read your signature at the bottom of the first post.....
Old Jan 13, 2005 | 06:40 PM
fordracerman
np i dont reccomend any starting fluid and was surprised when you said you would lol Im going to take it into work tonorrow and try and figure whats going on Thanks though. If anyone else has any idea feel free to recommend!
Old Jan 13, 2005 | 11:31 PM
Rogue427's Avatar
Rogue427
Wd
WD40 works good for starting a diesel. I would make shure your glow plug relay is working first. Tim R.
Old Jan 14, 2005 | 01:15 PM
fordracerman
relay is working i brought it into my shop so i could thaw it out lol ill have to dig alittle further thanks guys!
Old Jan 14, 2005 | 07:15 PM
ovaltrack's Avatar
ovaltrack
Is it running yet? The fuel may be gelled. You might try some power service 911 or other fuel conditioner which reduces the pour point if you don't already have some in the tank.
Other than that, a freind of mine had a similar no-start problem on his 7.3 PSD. It was a bad CAMP sensor (Cam Position Sensor). His would not run at all.
Old Jan 14, 2005 | 07:51 PM
cpl624's Avatar
cpl624
My last truck was a '99 7.3l, and I also had the same problem. Turned out is was a "brain" for the glow plugs. Good news is it was a quick fix (1 hour), bad news is the new computer listed at just over $850.00. Good luck.
Old Jan 14, 2005 | 08:04 PM
slc10844's Avatar
slc10844
Check the oil level in the high pressure oil pump resevoir just to make sure it's not draining back.
Old Jan 14, 2005 | 09:07 PM
fordracerman
i got it running today everything seems ok now. I already had a bad cam sensor so i know what that is like!i run a fuel conditioner regularly it seems to run much better with it tin it. I still dont think my glow plugs are working though.Anyone know where i can find a site with code codes i can read them just dont know what they mean ??? thanks again everyone
zakk
Nov 19, 2011 03:33 PM
Rollin.IH.Coal
Oct 31, 2011 08:35 AM
lifechanger
Apr 1, 2011 07:18 AM
justasammy
Mar 10, 2005 05:09 PM
diesel demond
May 14, 2003 02:34 AM
