How do the climate controls work?
Old Jan 11, 2005 | 09:12 AM
Sycostang67's Avatar
Sycostang67
On an 1985 F-250, the heater only blows through the dash vents, no floor heat or defrost. Is this operation controled by a cable or is it vacumn activated?
Old Jan 13, 2005 | 10:14 AM
73Custom's Avatar
73Custom
Was your truck made with factory a/c? If so, then it's vacuum controlled. Non a/c truck is cable controlled. I'd assume it's a a/c truck. Check that you have no engine vacuum leaks. Find the vacuum line that goes into the firewall and check that there is vacuum at the source.
Marty
njstevens
Oct 1, 2021 09:41 PM
mrwrench
Oct 19, 2009 01:25 PM
macguyver
Jan 15, 2003 10:25 AM
unreng
Aftermarket Products
Dec 5, 2002 09:34 PM
