engine/transmission shifts in reverse
when i put the truck in reverse under any load and let the clutch out the
tranny moves, u can feel it in the shifter probably up to 6 inches maybe 8inches
i can understand a couple inches but this is way too much
all the mounts are tight brand new motor mounts only helped for the same problem but going forward
i dont know im stumped
If you have a hill put it nose down and put in reverse and kill it, And get under it and look and see if you can see anything. Look at the trans mounts, and driver side motor mount.
sounds to me like a motor mount, or a bad tranny mount. i remember i had one with a bad engine mount and i thought it was gonna come out through the floor and fly out the window when in reverse.
