02 no reverse!?
Old Jun 1, 2011 | 03:26 PM
deathstar7.3's Avatar
deathstar7.3
02 no reverse!?
I have a 2002 7.3l its lifted 18 inches with the works..i pulled a trailer threw my yard in 4x4 low in reverse when all of a sudden stopped moving..all of my forward gears work fine still and if the truck is on flat ground in reverse it will slowley creap backwards if i gas it..tranny only has 84k miles on it..are there any typical things that happen to these trannys that can cause this problem before i pay for a full rebuild??
Old Jun 1, 2011 | 03:29 PM
texans's Avatar
texans
sounds like you are going to need a rebuild. Maybe a dumb question, but have you checked the fulid level?
Old Jun 1, 2011 | 11:36 PM
deathstar7.3
yes fluids good even changed it...its only reverse tho it shifts sooo smooth threw all forward gears
Old Jun 2, 2011 | 12:31 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Give John Wood a call, he is down in SoCal. He can give you a run down over the phone and advise you.
John Wood Automotive - Services
Old Jun 2, 2011 | 01:26 PM
farmb0y's Avatar
farmb0y
Probably need a rebuild. I don't have the lift, but was towing our big flatbed and skidloader, unloaded it, and went to back the truck up and had nothing. Luckily I parked where I could still pull out.
All forward gears still work fine?? Last year I had my transfer case go out on me, and left me to believe it was the tranny. The "transfer" gear slipped out of the forks and must of put me to the low side, because I could only get to about 40 mph tops, then it slipped out and I had nothing. Since you were towing in 4x4 low, could be something to check.
Old Jun 2, 2011 | 03:47 PM
deathstar7.3
But i can still go 80 mph on the freeway and if it was transfer case related wouldn't it effext for ward and reverse in the same way??..is there a way to test if it is the transfer case without taking the t case and transmission all the way out and tearing them apart?
Old Jun 2, 2011 | 04:16 PM
farmb0y's Avatar
farmb0y
It's probably your transmission then. When my T-case went, I couldn't move anywhere.
idiguy111245
Oct 8, 2013 04:07 PM
DieselBurner153
Mar 26, 2013 12:18 AM
chrison600
Oct 13, 2012 12:56 PM
chrison600
Oct 11, 2012 08:27 PM
nalicastro
Sep 21, 2010 11:27 AM
