stuck in reverse
Old Feb 23, 2009 | 01:13 PM
grizzlechunk's Avatar
grizzlechunk
stuck in reverse
I have an 89' f-250 4x4 with 302. My tranny is stuck in reverse, but can move shifter into all gears resulting in truck almost feeling like brakes are on and stalls. There is a shaft bolted to the driver side of tranny with a sprocket on the outside end that is popped out about a half inch. does anybody know what it is? And can someone tell me which tranny I have? It is a 5 speed. I think it is the mazda model but not sure.
Old Feb 25, 2009 | 05:54 PM
grizzlechunk
I did find out that I have the M5R2 transmission, and the likely cause is a broken reverse shift fork, which keeps it in reverse but also allows for shifting into other gears at the same time. Does anyone know if I can get to that without dropping the tranny? Also, why does this truck have an f-150 tranny, shouldn't it have the Z.F.? Will the Z.F. work with the 302? I would appreciate any help.
Old Feb 25, 2009 | 06:35 PM
BigBlueOx's Avatar
BigBlueOx
You have to take the tranny out and all apart to replace shift forks. The ZF will work with the 302. And no it wouldnt come with a ZF unless you had a 5.8L or bigger.
Old Feb 25, 2009 | 06:55 PM
grizzlechunk
Thanks Blue, I'm going to get the Z.F. then. I'm not confident enough to split a transmission, lol.
GM4WALLS
Mar 25, 2014 04:58 PM
kc7nwi
1983 - 2012 Ranger & B-Series
Oct 2, 2012 07:55 PM
lumpy1
Feb 4, 2007 04:41 PM
