1986 fuel problem
Old Aug 21, 1999 | 06:56 PM
1trent's Avatar
1trent
1986 fuel problem
i have recently experienced sluggish excelleration and very little power. I first thought it was a filter or pump. The filter was replaced and i put a new high powerd pump in that sits on the frame. these did not solve my problem.
I put the old pump back in and now it wont even start. my next move is a fuel pressure regulator.
any other suggestions?
Old Oct 19, 2002 | 07:31 PM
jason9009's Avatar
jason9009
1986 fuel problem
my truck had some problems. it would jump and buck when you accelerated alittle bit. you would have to ride down the road going about 30mph and if you went any faster it would buck. so we drained the fuel because it was about 2 years old becuase the truck was stored and we put new fuel in and we couldnt get it to start. so we bought a new fuel pump, put new plugs and wires and all new filters and it still has the same porbolem..any ideas?
Old Oct 19, 2002 | 11:50 PM
mtflat's Avatar
mtflat
1986 fuel problem
[updated:LAST EDITED ON 20-Oct-02 AT 00:53 AM (EST)]Anytime my '86 has random wierd symptoms the first thing I do is slap in a new ignition control module (on the side of the distributor).
They'll cause some pretty goofy things to happen when they're failing and when they die completely the engine won't start - it'll crank and crank but won't fire.
Old Oct 21, 2002 | 07:36 AM
86F250beast's Avatar
86F250beast
1986 fuel problem
i had similar problems with my inline efi I've replaced everything form tank up to injectors twice on my inline and am starting on my f-250 302. Sounds like the filter in the tank on the end of the intank pump. replace that and clean out your hoses and filters and it might do ok.
ford feul master
kelly
Old Oct 21, 2002 | 07:47 PM
riverguides's Avatar
riverguides
1986 fuel problem
I had similar problems, also replaced filters and a few mechanics tried to get me to replace fuel pumps wich I did not. I replaced the fuel pressure reg. and that did the trick. runs like a champ after that. good luck. let me know.
Chris
Old Oct 22, 2002 | 01:52 AM
dpoelstra's Avatar
dpoelstra
1986 fuel problem
depends on what truck you have and what engine. In a carb model, I would suspect timing being retarded. Check your timing, plugs, cap and rotor, wires etc...
if you are fuel injected, I am not even gonna guess. they confuse the heck outta me.
On the 86 460, the ignition control module is not always on the distributor, some are on the fenderwell.
Old Nov 10, 2002 | 07:55 PM
82F100SWB's Avatar
82F100SWB
1986 fuel problem
Old Nov 11, 2002 | 07:33 AM
bdnow's Avatar
bdnow
1986 fuel problem
What about an '83 F-250?
-Allan
Old Nov 11, 2002 | 09:09 AM
Ford_Six's Avatar
Ford_Six
1986 fuel problem
83 F-250 should have DSII, a big box mounted on the fenderwell.
Jared
Old Nov 11, 2002 | 11:49 AM
johnfl's Avatar
johnfl
1986 fuel problem
Anyone notice the 1st post of this thread was in August of 1999? I wonder if he fixed it yet.
JohnF
RUSTY50F1
1978 - 1996 Big Bronco
Feb 6, 2015 05:00 AM
rdz
Jan 29, 2014 06:14 PM
08gasurveyor
Feb 6, 2013 03:48 PM
monsterbaby
50
Mar 25, 2006 01:11 AM
MrV300xlt
Oct 23, 2003 01:41 AM
