window seals
Old Nov 6, 2002 | 09:50 PM
Last2Know1's Avatar
Last2Know1
window seals
I have a 1986 F-150 paid $500.00 for the truck and I'm in the process of putting on a 6 inch lift with 35 inch tires, anyway when I'm on the freeway and my windows are rolled up wind noise is pretty loud, where can I find the replacment window seals
Old Nov 6, 2002 | 10:57 PM
steve83's Avatar
steve83
window seals
JC Whitney, Ford, LMCTruck, ...
Old Nov 6, 2002 | 11:24 PM
Mil1ion's Avatar
Mil1ion
window seals
There is an AD on the top of this page that says:
Weather-stripping & Window seals .
Maybe THINK here, First
They are available here motorhaven.autoanything.com
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 8, 2002 | 07:44 PM
Last2Know1's Avatar
Last2Know1
window seals
I still can't find the seals I went to the web sites and I just can't narrow it down. If you know where to find them let me know.
Old Nov 12, 2002 | 09:15 PM
OldFords's Avatar
OldFords
window seals
[updated:LAST EDITED ON 12-Nov-02 AT 10:20 PM (EST)]I just replaced the window seals and anti-rattle strips on my wife's 1981 F100. It wasn't that difficult.
The only time-consuming part was replacing the inner anti-rattle strips (on the door panels). They are installed to the inner door panel using staples, which must be removed carefully so as not to crack the panel.
I have a Sears "industrial" stapler (read manual stapler with stronger spring), but it could not punch a staple all the way through the anti-rattle strip AND the panel. So I saved as many of the old staples as I could, and used the old strip as a pattern to mark the new strip. I used a very small drill bit to punch holes in the new strip at the same places as the old. Then I pushed the old staples through the strip and then through the old (existing) holes in the door panel. Using a pair of needle-nose pliers, I bent the staples over tight against the back of the panel. I used some of the staples that came with my stapler to replace the ones that were broken. Worked very well, and the truck is really quit now.
I also replaced the "felt" window channels at the same time. The door glass doesn't have to be removed from the door, but I had to loosen the channel adjustment bolts in order to get enough space between the door glass and the metal channel for installing the new "felt" channels.
If you still haven't found replacement parts, email me at
market@zianet.com and I'll give you a hand.
OldFords bad attitudes
Old Nov 12, 2002 | 10:01 PM
steve83's Avatar
steve83
window seals
rews2
Feb 25, 2015 05:51 PM
68f10059
Dec 6, 2013 04:34 AM
TBucketJack
Feb 21, 2005 09:35 PM
TexasBronco
1978 - 1996 Big Bronco
Sep 21, 2003 06:37 PM
loudfords
Jul 28, 2003 12:34 PM
