1978 - 1996 Big Bronco
90 Bronco Vent Window Leak
Old Sep 21, 2003 | 08:37 AM
TexasBronco's Avatar
TexasBronco
The vent window on my 90 Bronco leaks badly because the forward end of the window doesn't close comletely against the seal. The seal looks OK and the window doesn't look warped, so I'm at a loss to how to improve sealing.
Anyone solved this or have some suggestions?
It looks like removing the window will require grinding a rivet out, but I hesitate to do that w/o some idea of how to improve sealing.
thanks
Old Sep 21, 2003 | 10:43 AM
wayne100's Avatar
wayne100
You can try to move the outside bracket(hinge?) with a pair of pliers. Be carefull you just need to move it a little bit. If the bottom of the window leaks try to move it up, this will put more pressure on the bottom of the window.
Old Sep 21, 2003 | 06:37 PM
TexasBronco
Yes, after looking closely at the upper hinge post, I can see it is positioned further outboard than the pax side. I will try to adjust, carefully as you suggest.
Thanks for the tip!
Regards
78bigunns
18
Nov 27, 2013 07:16 AM
oatsj
Sep 27, 2009 11:33 PM
berry1234
15
Dec 7, 2007 08:00 PM
seawulff
20
May 11, 2006 05:37 PM
svgearhead
Jun 15, 2004 08:44 AM
