Just got an e-mail from Dale Isley. Wow what a wealth of knowledge. I would like to just pick his brain for awhile. Anyhow he gave me the run down on this filter. It is a better filter than stock and flows better as well. He answered all my questions that I had. I'm going to get one, as soon as I figure out what chip top get. Jamie
From my personal experience Dale at Tymar will bend over backwards to help and he is an encyclopedia of information. Highly recomended -- give him a call
It looks simple enough. If I was only going to run it on the hiway I wouldnt worry about it. But being a welder I'll be in the dust alot. I am wondering which tuner is better for the 7.3 Bullydog or the new superchips. Do you know? I like the multi hp options but dont want to melt it down either. Jamie
...............Better checkout the Juice\Attitude setup before you get hungup on those other you mentioned! sk
The tymar is a PAPER filter. Just throw it away after about 20,000 miles or so. It filters better than ANY oil/cotton filter (such as K&N or AFE) but it does have a slightly higher restriction than the oil/cotton (hardly measureable tho).
It blows the stock filter away!! It also has a high "load" ability, meaning it can hold a LOT of dirt without affecting restriction to much.
Its a little old now, but the data should still be good. The "Baldwin" is the same as a Tymar in that study. It has good flow and low restriction, along with high filtration and high loading. Just an overall good filter.
That's because both Donaldson and Baldwin sell the Duralite filter that is used on the Tymar intake. Only those two companies are licensed to use the filter media which repels water.
As to the restricton compared to cotton filters, the Tymar will still have less filtration because it is an open element design and it is larger than the filters I've seen by K&N and others.
You changed topics. Restriction or filtration?
It has BETTER filtration that the others, with only the slightest sacrifice in restriction compared to the others. As per the data charts I posted above.
