Front Axle Swap
Old Jan 4, 2005 | 05:53 PM
morrigj83's Avatar
morrigj83
Front Axle Swap
I have a 92 F-250 4x4 with IFS. I want to swap to a straight front axle with the least amount of brake and sterring conversion possible. I think a one ton from the same era will work. I am planning on putting gears in it anyways so that doesnt matter. Does anyone know what truck to look for or hase anyone done it?
Old Jan 4, 2005 | 09:28 PM
dsldandually's Avatar
dsldandually
80 and up f-350 will have a Dana 60 that is what you want to look for! Good luck they are big$$$$
Old Jan 4, 2005 | 10:08 PM
Mr Man's Avatar
Mr Man
It's a very straightforward swap. But as dsldandually said, Dana 60s aren't cheap. Make sure you get the steering linkage (everything below the pitman arm), track bar and bracket, U-bolt brackets, and front driveshaft (it's about an inch shorter).
Also, try to get the axle from a 92-96 truck. The brake calipers are different on the older axles, and it will throw off your front to rear brake balance. That's what happened to me anyway.
Scott
Old Jan 4, 2005 | 10:37 PM
SoCalDesertRider's Avatar
SoCalDesertRider
'80-'85 F350 4x4's had the independent front axle like the F250's (Dana 50). '86-'97 F350's were straight axle. '86-'91 had kingpins and '92-'97 had ball joints, both Dana 60's.
brcwelding
16
May 7, 2012 08:44 PM
Powermonger
Sep 29, 2011 06:35 AM
TheresHellToPay
Nov 9, 2009 01:26 PM
mike93082
Bronco II
Apr 10, 2006 04:58 PM
