axle swap
Old Sep 27, 2011 | 07:08 AM
Powermonger's Avatar
Powermonger
axle swap
My 95 PSD 4x4 has a split front axle can I swap it for a solid front axle?
Old Sep 27, 2011 | 07:38 AM
bleeds blue's Avatar
bleeds blue
Absolutely. Do a search on here. There are a million posts about swapping the Dana 60 in.
Old Sep 28, 2011 | 07:11 AM
Powermonger
axles
I was hoping so Thanks for letting me know.
Old Sep 28, 2011 | 08:06 AM
Neal 97 250's Avatar
Neal 97 250
Dana 60 from a Ford is what you will be looking for.
Old Sep 28, 2011 | 11:30 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
From I believe 86-97 F350. Get all the brackets that bolt to the cross member (under the oil pan) and the brackets between spring and axel and springs also. Do not use the F250 springs. They are way stiffer then the F350. I tried it and it was like riding a lumber wagon, you feel every pebble in the road. I used the F350 springs from the donor truck that I got everything else from. The truck was a 460, single cab truck and mine is a 7.3 diesel crew cab and the springs work good.
Old Sep 29, 2011 | 12:48 AM
Powermonger
axle swap
so I'll start looking for a dana 60 front end with all the goody's and go from there.Thanks for the info.
Old Sep 29, 2011 | 06:35 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Here Is a picture comparison of front springs from a f350 460 and f250 7.3 bottom spring is the f250. But that f350. Spring is working great.
Icuff4cash
Aerostar
Jun 1, 2016 09:17 PM
betuo
Jan 28, 2011 08:35 PM
429PI IN 75 f-100
Apr 17, 2009 09:37 PM
vento
1978 - 1996 Big Bronco
Jan 26, 2006 10:36 PM
jessecoit
Dec 16, 2003 03:16 PM
