Hello,
I am a new member. I have a 66 f100 stepside (obviously) that I bought from the original owner two years ago. It had not run in many years when I got it.
I stupidly broke a pressure plate bolt in the flywheel while replacing the clutch.
I am not able to find this flywheel in my parts catalog. Any help would be greatly appreciated. I just became aware of this site, and am really enjoying reading the archives.
Thanks, James Q.
Thanks for the replies. I have tried to drill out the bolt w/no success. I am going to remove the flywheel and thought it would be just as easy to replace it as to fix and resurface the original.
James Q
James you can use one up to 76 (last year used) 352, 360, or 390. Most parts houses should carry them or have it next day. Try asking for a 76 360 F150, maybe they can find it then.
