66 brake light puzzle
Old Feb 20, 2005 | 01:03 PM
66lastepside's Avatar
66lastepside
Hello,
I am looking for non-working brake light suggestions. I have replaced the master cylinder, brake light switch, fuse, and light bulbs. I have working tail
lights and turn signals. Any sugestions?
Thanks, James Q
Old Feb 20, 2005 | 02:41 PM
barry's Avatar
barry
Have you tried to jump the brake light switxch? Take the 2 wires off it and connect together. They should light up. if so, the brake light switch is bad. If not, there's a break in the wires somewhere or the signal light switch under the steering wheel is bad. They route the brake lights thru this for some reason. Test the B/light sw. wires with a test light, you should have power in one of the 2 wires.
Barry
Old Feb 20, 2005 | 06:41 PM
66lastepside
Hi Barry,
I did jump the wires on the switch and did not get any lights. The turn signals work.
Does this eliminate the switch under the steering wheel?
Thanks, James Q
Old Feb 20, 2005 | 07:52 PM
barry's Avatar
barry
I'd trace back the wires to see where the power is supplied. The signal light switch can be a culprit. I sold alot of those back in the 70's.
Barry
Old Feb 20, 2005 | 08:15 PM
bertha66's Avatar
bertha66
Are you checking the lights with your keys in the on position? The brake lights do not work unless the keys are on, or if the engine is running.
Old Feb 21, 2005 | 03:44 AM
daveengelson's Avatar
daveengelson
Been some time since worked on my 65 brake system. Wonder if can test circuit by removing the 2 wires from the brake switch, assuming pressure type, and while one presses brake pedal can someone test across the switch. Since mentioned also replacing M/C wonder if air pocket not allowing required pressure to activate switch. At least determine if switch is faulty and start from there.
dave
Old Feb 21, 2005 | 10:27 PM
voodoosurfer's Avatar
voodoosurfer
I made a litlle drawing for future reference if I ever needed it, if My drawing is incorrect please let me know I would hate to have led someone astray. anyway I had the same problem and it was my connections under the bed back by the rearend. there should be 3 wires which split into 4 (2 to each side) mine were all cracked and not connecting good. once I replaced all of them it all works flawless. you might try messing with this area.Brake diagram between axle and bumper
Old Feb 22, 2005 | 04:23 AM
jowilker's Avatar
jowilker
Dave, One of the wires should be hot with the ignition switch turned on. You gotta have that before you can go any further.
John
Old Feb 22, 2005 | 08:40 AM
Putt's Avatar
Putt
I ran into this recently and it was a bad ground at the rear of the truck in addition to a poor connection at the fuse box. A bad ground can cause all sorts of strange symptoms!!
Old Feb 22, 2005 | 09:10 AM
RanchRodsTX's Avatar
RanchRodsTX
My brake lights work even with the switch off. The air void in the Master Cylinder was a real pain in the A** for me. Dave, where were you when I was slashing my wrists over this problem. Redid the whole wiring harness from the bed back without success, then a very wise man suggested I try to bleed fluid at the switch. BINGO!
Old Feb 22, 2005 | 08:08 PM
66lastepside
Hello all,
Thanks for the suggestions! Voodoosurfer, I could not open the link you posted. The air pocket below the switch sounds like a possibility as well. Where is the ground strap at the rear of the truck?
Thanks again, James Q
Old Feb 22, 2005 | 08:10 PM
66lastepside
Hello again,
I was able to open Voodoosurfers' link on a later try.
Thanks, James Q
Old Feb 22, 2005 | 08:26 PM
barry's Avatar
barry
Behind the rear lamps you'll see a ground wire going to the body. Clean where they attach and also make up a ground wire to connect to the frame. It won't hurt to do this even if it's not the problem.
Barry
Old Feb 23, 2005 | 07:41 PM
66lastepside
Hello Barry,
I looked under my truck and all I see is the rear light harnesses. I don't see any grounds at all. Could I ground from the lamp assemblies to the frame? This is a stepside truck. Also, do my working turn signals rule out the switch under the steering wheel being bad?
Thanks for all your help, James Q
Old Feb 23, 2005 | 08:03 PM
barry's Avatar
barry
No it doesn't rule out it being bad. Take the tail lamps off the brackets and clean where they mount. Make sure they're nor rusty inside. You may have to hook a ground from the body to frame. Did you try bleeding the air out at the master cyl?
Barry
