Sponsored by: Auxito
Accesory Delay
Old Dec 29, 2004 | 01:34 PM
carlixtros2's Avatar
carlixtros2
Question Accesory Delay
Hi eveybody!
This is my first post in this forum
Hope someone can help me with my question,
it is about how it works accessory delay, I want to enable it because my truck does not have power windows, but I'm about to buy a new installation kit to do so, is it necessary to buy a some kind of new electronic module or if the module for accessory delay is already installed on my truck what wiring connections should I do?
I have a F-150 1998 Triton V-8 4.6L regular Cab with no power windows .
sorrry for my bad english (I'm still learning )
Sincerely
Carlos A
Old Dec 29, 2004 | 11:41 PM
Racerguy's Avatar
Racerguy
Hi Carlos and welcome to the forum
Your English is as good as most of the people on here so don't worry about it
Is the power window kit you're getting an aftermarket kit? Do you have a link to a website that shows the kit?
I think you probably will just need to wire it so it has power when the ignition is on so you shouldn't have to do anything with the accessory delay.
I'm not positive if your truck already has an accessory delay relay or not. The GEM (Generic Electronic Module) in a truck with power windows is different than the CTM (Central Timer Module) that your truck uses but I'm not sure what all is different.
Old Dec 30, 2004 | 01:12 AM
carlixtros2
Hi RacerGuy, thanks a lot for your reply, a thanks for the welcome
yes, it is a aftermarket kit, I don't remember if the product has website available,
I read in the owner's manual that there was an accessory delay feature available for vehicles equipped with power windows so that you could use the windows for about 10min after the ignition was turned off, and I thought that it would be nice to have that feature available on my truck, I looked for the "ACC delay" relay in the fuse panel but it was empty, (relay No 5 according to the owner's manual), I thought that I could enable that feature, but i see that is not possible, I'm gonna do what you told me to do, I have already found the wire that the power windows need to get energized when you turn on the ignition it is one that is gray and it also has a yellow line and comes from the steering column.
I got the part number of the module that is above of the fuses, I don't know if that module is the GEM or the CTM, F75B-14B205-LB
Thanks a lot for taking your time to reply my post and for your advice.
Strokin-A-2010
Feb 5, 2017 04:39 AM
DCP
Jan 4, 2016 02:36 PM
21modelt
Dec 9, 2015 07:56 AM
turnkyle
Dec 31, 2011 11:53 AM
Rob04
Jun 28, 2006 10:26 AM
