Sponsored by: Auxito
Is pitman arm going bad?
Old Oct 12, 2002 | 07:22 PM
z 97ford1's Avatar
z 97ford1
97f150 4x4 4.6v8 auto 136k miles new bfgoodrich k/m mudterrains:
Had my truck aligned the other day. There was a pull to the right before and a pull to the right after. Alignment people showed me the data after the fact and it showed it was aligned.
They suggested a add on "device" that would help the adjustment and perhaps align it true.
Would a defective pitman arm cause the truck to pull to the right?
I was told by a mechanic (a couple of years ago) that there was evidence of the pitman arm going bad and to keep an eye on it but no one else has said anything about it.
Anyone have any thoughts on this?
Thanks,
Old Oct 12, 2002 | 08:27 PM
Racerguy's Avatar
Racerguy
No a pitman arm wont make it pull.
A good alignment shop will adjust the camber and caster to get rid of the pull. You might also try swapping the front tires side to side and see if that changes it.
Old Oct 22, 2002 | 12:37 AM
chevrolet's Avatar
chevrolet
bad alignment isn't the only thing that can cause a pull, so how can you be so sure that a good alignment shop can get rid of the pull.
Old Oct 22, 2002 | 01:05 AM
Toolman II's Avatar
Toolman II
Old Dec 30, 2004 | 01:24 AM
Dannie360's Avatar
Dannie360
Pitman arm
My 97 f-150's has a squeel when steering, I thought it would have been the steering box. When I Had someone else turn while I inspected it, come to find out all I had to do was grease my pitman arm. I have reccently found that this is a common problem like the rear window calk displacement leak. As far as pulling to the right, pitman arm should not be your problem.
chadjetlag
Jun 15, 2015 08:46 AM
Fordx4jake
May 31, 2015 12:02 PM
caminokid863
1997 - 2003 F150
May 9, 2015 09:09 AM
tractoman
May 10, 2014 10:50 AM
JOE SKI
1997 - 2003 F150
Mar 6, 2014 09:46 PM
