Dtc B1302
Old Jun 27, 2006 | 09:51 PM
Rob04's Avatar
Rob04
Dtc B1302
Hi Everybody, this is my first post although I am an admitted lurker on FTE and have learned a lot reading the posts.
I have a 2001 F-350 XL 4X4 with the 7.3 liter diesel. The only upgrades I have are an AIS filter and a Walker BTM.
I just got my autoenginuity software yesterday. When I ran the KOEO test, the DTC code B1302 - Accessory Delay Relay Coil Circuit Failure - came up. The software also told me that it has to do with the GEM module.
I'm lost. Do I check for a blown fuse or relay? Or am I looking at buying a new GEM module?
Thanks for your help. Rob
Old Jun 28, 2006 | 09:59 AM
cangim's Avatar
cangim
There is a delay relay that is under the dash in the fuse panel, you might try that one. But that is just a guess.
Old Jun 28, 2006 | 10:03 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Hi Rob. Welcome to FTE.
Are you having any problems with any of the components run by the GEM? Warning chimes, interior/exterior lamps, keyless entry, wipers, power windows, ESOF?
If everything is working I think I would just ignore it until something stopped working. The GEM is powered through fuse #19 in the central junction box....the fuse box under the dash.
Old Jun 28, 2006 | 10:26 AM
Rob04's Avatar
Rob04
Hi Cookie88,
No, I am not having any problems with components run by the GEM. I will just ignore the code until I have problems. I will check fuse #19 though. Thank you for the advice.
Rob
Wrecking ball
Jul 24, 2021 02:08 PM
jimjokjv
Aug 2, 2017 06:59 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 28, 2016 08:09 AM
Rusty Axlerod
Nov 5, 2015 04:29 PM
Tkrobinson
Sep 25, 2015 08:39 PM
