OBD II location
Old Dec 27, 2004 | 01:15 PM
csft's Avatar
csft
OBD II location
1997 F250HD, old body style, 351w, E4OD.
The computer is hid under the parking brake assembly.
Does anyone know where the OBD connector is?
Old Dec 27, 2004 | 04:19 PM
EPNCSU2006's Avatar
EPNCSU2006
It's likely still an OBD-I, with the connector under the hood. If it is OBD-II, the connector would likely be attached to the bottom of the dash. You shouldn't have to search for it - it should be obvious if it is there or not.
Old Dec 27, 2004 | 04:38 PM
stevef100s's Avatar
stevef100s
It's OBDII. Half of 95 and all of 96 and up Fords are. On my 96, the plug is under the dash in the center aprox.
Old Dec 27, 2004 | 06:20 PM
crazandy's Avatar
crazandy
Not 100% true. My 97 F250 460 (built in august 97) has OBD-I.
Old Dec 27, 2004 | 06:42 PM
stevef100s's Avatar
stevef100s
Hmmmm. Thanks for the insight. Didn't even know the 460 was available in 97.
Old Dec 28, 2004 | 08:01 AM
EPNCSU2006's Avatar
EPNCSU2006
The heavy duty trucks (over 7700 gvwr) didn't have to go to OBD-II at the same time as the F150 and light duty F250. The heavy trucks were carry overs until the new super dutys came out as a '99 model. No '95 F-series trucks should be OBD-II.
Old Dec 28, 2004 | 11:19 AM
csft's Avatar
csft
Thanks
Thank you for the help
John Hubbard
Sep 25, 2015 09:28 AM
skipcox
6.7L Power Stroke Diesel
15
Sep 9, 2015 03:37 PM
therigwelder
Jul 30, 2015 08:24 PM
Firefighter6601
Jan 26, 2015 08:56 PM
jle70
Jul 20, 2014 03:07 PM
