1999 Explorer throwing P0126??
Old Dec 23, 2004 | 10:44 PM
jasonball's Avatar
jasonball
Changed the coolant sensor but coolant gauge still doesnt read and the CEL is still on. Any ideas?
Old Dec 24, 2004 | 08:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and read the headings… Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Happy Holiday.
Enjoy FTE
Old Dec 24, 2004 | 08:21 PM
87 XLT's Avatar
87 XLT
You changed the single wire temp gauge sending unit or was it the 2 wire engine coolant temp sensor?
Old Dec 24, 2004 | 09:15 PM
87 XLT's Avatar
87 XLT
BTW, even on these newer eletronic marvels, I think it's still possible to simply ground the temp sender wire to see if the gauge is working. Maybe one of the other guys will know for sure.
Old Dec 24, 2004 | 09:39 PM
jasonball's Avatar
jasonball
I changed the single wire one. Is this the right one?
Old Dec 24, 2004 | 11:56 PM
87 XLT's Avatar
87 XLT
Yes, that's the one thats wired to the temp gauge. On older trucks all you had to do to see if the temp gauge was working was to remove the wire from this sending unit & ground it beside the sender & if the temp gauge showed full hot, it was working as it should. Not sure if you can do this on yours or not.
Strange that the temp gauge not working would give you a PO126 (not going into closed loop) maybe one of the other guys will know whats going on here.
Old Dec 25, 2004 | 12:15 AM
87 XLT's Avatar
87 XLT
Or maybe the T=stat is stuck open & it really is running cold.
Old Dec 27, 2004 | 10:16 AM
thelonerangerxlt's Avatar
thelonerangerxlt
The engine coolant temp sensor is the one that controls open/closed loop operation. It's located near the temp gauge sender, but I can't remember right off which one is which. I'm thinking that the gauge sender has 1 or 2 wires and the coolant temp has either 2 or 3...?
This too is a possibility.
alexisricker
Mar 17, 2015 10:07 PM
tjustice
Jan 20, 2014 05:31 PM
stever88
Nov 25, 2013 03:34 PM
jedi8164
Escape & Escape Hybrid
May 5, 2007 09:48 PM
parks911
General Automotive Discussion
Mar 5, 2006 03:39 PM
