Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Low Coolant Light
Old Mar 17, 2003 | 02:43 PM
jedi8164's Avatar
jedi8164
Low Coolant Light
My 2001 Ford Escape's low coolant light will not keep from coming on. I noticed it the other day and so I checked the coolant overflow and it was a little low. I followed the instructions in the manual and added the 50/50 mixture to the overflow. However the low coolant light still comes on after driving for awhile. It doesn't stay on all of the time, it will eventually go off. I am confused! Any ideas?
Old Mar 17, 2003 | 02:56 PM
PrPlayboy's Avatar
PrPlayboy
Low Coolant Light
Check the float in the over flow resivor. It could have some build up on it. Maybe it went low for a while and the rod that the float sits on got dry and left over coolant made it sticky.
Old Jun 19, 2003 | 06:24 PM
escape radar's Avatar
escape radar
Low Coolant Light
My 2001 Escape just turned over 55,000 miles and my low coolant light has been going on and off also (usually after I drive about 40 miles). My coolant level is ok. I have had various problems with this vehicle so I called the dealership right away. They told me that if the coolant level is ok then it is probably a sensor problem and it may need to be replaced, but that as long as I check the coolant, I can drive it until I have a chance to take it to them.
Old Jun 19, 2003 | 06:58 PM
1956MarkII's Avatar
1956MarkII
Low Coolant Light
I have to agree with escape radar- most likely a defective sensor in the overflow tank. As long as you keep an eye on the coolant level, it should be OK for awhile.
Old Jun 20, 2003 | 02:24 PM
pilot10's Avatar
pilot10
Low Coolant Light
I think it's probably an oversensitive sensor. My parents Mercury Mystique's coolant light comes on often. Fluid is always within limits and the sensor has been replaced twice. Normally adding a teaspoon of fluid - not even a tablespoon- is enough to turn the light off.
Now what I do when the light comes on is slightly overfill it- maybe 1/8" to 1/4" over the max line. Then the light stays off for 4-6 months.
Just keep your eye on the overflow tank to make sure there's fluid.
Tim
Old Mar 29, 2007 | 10:51 AM
8dzaweek's Avatar
8dzaweek
I had all three lights come on, check engine, low coolant aqnd the brake light.
Ford has Teck Service Bulletins on all three for faulty sensors and the brake cap will not hold pressure and leaks out the brake fluid.
Fords Customers service dept (dealer will deny all) will assist you with the cost of replacing the cap and sensors (about $500) You can buy the part however for less that $150 and install them yourself if it comes to that.
I have been around and around with fORD WITH THIS and they have put me off until I went to the NHTSB and got the other thousand complaints about these TSB's, now they want to pay half the cost as a "good will" gesture.
Old May 5, 2007 | 09:48 PM
osbornk's Avatar
osbornk
Mine did the same thing and they replaced the overflow tank due to a bad sensor. Seems like it was $70+ but I didn't care since it was a company car at the time.
Nicholas Saavedra
May 11, 2017 04:06 PM
DuallyCowgirl
Nov 28, 2012 12:22 PM
MSUslacker
6.4L Power Stroke Diesel
Dec 26, 2010 04:23 PM
nikm7
Nov 3, 2009 10:36 AM
14u2nv
Aug 28, 2006 08:28 AM
