Busted Driveplate (PICS)
Old Dec 24, 2004 | 11:20 PM
95EXPLODER's Avatar
95EXPLODER
Out of a 96 Limited.
http://www.clubfte.com/users/heavymentill/myX022.jpg
http://www.clubfte.com/users/heavymentill/myX023.jpg
http://www.clubfte.com/users/heavymentill/myX024.jpg
http://www.clubfte.com/users/heavymentill/myX025.jpg
http://www.clubfte.com/users/heavymentill/myX026.jpg
Symptoms of this are noisy torque converter at idle. Sounds like the torque converter is making contact with bellhousing. Sound only noticable at idle or when throttle not depressed. Finally one day after backing up out of a parking place I proceeded to to drive forward about 3 feet then bang RPM's shot up I just sat there wouldn't move in any gear. Engine running with the sound of rubbing metal coming from the driveplate. I shut the engine off an from then on it wouldn't start, starter would turn, just not the crankshaft. Seems to me like they cheaped out on the driveplate in 96. I replaced with a 95 driveplate which in my opinion was much higher quality. Also replaced the torque converter while I had it apart, since the one in there had taken a beating and I didn't want to drop the trans out twice. Now all is well!
Last edited by Racerguy; Dec 25, 2004 at 10:57 AM. Reason: converted huge pics to links
Old Dec 27, 2004 | 10:32 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Scary pictures, 95Exploder. Thanks for posting; that's a common problem for the earlier models. Ford changed to a single piece flexplate on the later models.
