Leaky coolant filter valves
Old Jan 19, 2014 | 11:44 AM
tjustice's Avatar
tjustice
Anybody had trouble out of their coolant filter valves? Mine are starting to leak around the on/off handle, tried to tighten up, but still leak.
Old Jan 19, 2014 | 12:08 PM
npccpartsman's Avatar
npccpartsman
What brand of delete did you do? I have read of issues with some valves but it's been a while. It may be cheaper for you to just swap out the valves than trying to take up the issue with the vendor unless they'll replace them free.
Old Jan 19, 2014 | 12:11 PM
tjustice's Avatar
tjustice
Sinister..... yea figured just easier to replace, just wondered if anyone else been having issues
Old Jan 19, 2014 | 12:16 PM
npccpartsman
It may be that the sealing washers aren't compatible with the coolant but you'd see that posted if there were problems since Sinister is pretty popular among the diesel community. I wouldn't hesitate to contact them.
Old Jan 20, 2014 | 12:18 AM
retiredsparky's Avatar
retiredsparky
Incompatible valves are most likely the right answer-coolant will act as a catalyst or solvent with certain plastics and will harden that plastic in a very short time. (Drop a piece of clear plastic tubing into a tub of antifreeze and it will turn hard in less than an hour.)Unfortunately vendors cannot always be sure that their specifications are met when buying parts for resale, especially from "a certain overseas country". The shaft seals and seats in valves are not made from the same material in every application. Please let us know what you find out, since there are a lot of us with coolant filters/valves. Thanks, Larry
Old Jan 20, 2014 | 01:13 PM
loubell's Avatar
loubell
First, let's not start a silly "bash sinister" thread over the valves or their seals. I have never done business with them, but I know they are one of the larger and more respected vendors out there.
Second, I installed 1/2" brass valves from Lowes that were similar in price to the ones offered from the aftermarket companies, but are larger, and on the surface seemed much more durable and have held up so far 6 years without an issue.
They aren't as aesthetically pleasing, but my filter is mounted on the passenger side frame rail.
Old Jan 20, 2014 | 01:55 PM
BLADE35's Avatar
BLADE35
I used a Valve Like this from Home Depot
3 years running so far so Good
They have a Smaller Handle
https://encrypted-tbn3.gstatic.com/i...PK4bmz0dXDsMIC
https://encrypted-tbn2.gstatic.com/i...upzH2mprLu_-nQ
Old Jan 20, 2014 | 03:18 PM
npccpartsman
Originally Posted by loubell
First, let's not start a silly "bash sinister" thread over the valves or their seals........
Agreed. Any valve can leak no matter whose or how good it is.
Old Jan 20, 2014 | 04:19 PM
MisterCMK's Avatar
MisterCMK
Call Sinister. I bet they send you out new valves.
Old Jan 20, 2014 | 05:31 PM
tjustice's Avatar
tjustice
Best I can read not one person bashed Sinister, I just asked a simple question, a member asked me who I got them from and I replied....Now if thats bashing, u guys need to read more post.....I have bought many things from them and will continue to do business with them....
Justin Jones
Apr 20, 2016 03:16 PM
Jesser02EX
Feb 17, 2014 12:22 PM
Poorboy04
Feb 27, 2013 02:42 AM
rocky1074
Sep 25, 2009 12:48 PM
biawokauns
Apr 27, 2009 10:19 PM
