Oil Cooler Info
Old Dec 20, 2004 | 10:34 PM
patriottow's Avatar
patriottow
Question Oil Cooler Info
90 f 350 7.3 4x4 auto.Bad oil cooler.Has any done this before?Iv heard the bolts can brake while being taken out?Should I replace whole cooler?Iv got new O rings but heard it could be hair line cracks in cooler?Only the oil is leaking(very bad)no antifreeze?
Old Dec 20, 2004 | 10:44 PM
PLC7.3's Avatar
PLC7.3
If the oil is leaking at an oring then I would do orings only, then do the required pressure tests which would tell if any other problems were there. An IH dealer may be able to assist you with tests etc.
Old Dec 22, 2004 | 10:53 AM
Spectramac's Avatar
Spectramac
Once you get it off and apart it should be obvious if the O-ring is the problem. They are usually hard as a rock and cracked. The cooler itself is pretty stout, I'd be surprised to see one broken.
Old Dec 24, 2004 | 02:44 PM
patriottow's Avatar
patriottow
Thanks for the info.I`ll be doing this weekend.I`m going to try it with out jacking the motor i have custom exahust my be room.I`ll post how it went.
El Camino Man
6.4L Power Stroke Diesel
May 15, 2013 10:33 AM
dodgehemi0
2009 - 2014 F150
Feb 15, 2012 10:01 AM
olfordsnstone
Aug 27, 2010 01:49 PM
03superdoody
Dec 10, 2009 02:47 PM
