Troubleshooting The Cruise Control?
Old Dec 20, 2004 | 06:58 PM
ECONOLINITIS's Avatar
ECONOLINITIS
Is there a good troubleshooting proceedure for a dead cruise control (88 Econoline 150, 302V8)? I tried the cruise control for the first time and got no response - where might I start to find out why? All the vacuum lines seem to be attached and undamaged, the electrical connection as well.
Old Dec 20, 2004 | 07:36 PM
95 F150's Avatar
95 F150
May not be the same but my cruise control problem turned out to be a blown 15amp fuse in the power distribution box under the hood, granted this was on a 95 model F150.
Old Dec 20, 2004 | 10:26 PM
pfogle's Avatar
pfogle
Check the fuses and relays, if that doesn't work have the speed sensor in the trans replaced. It could also be a bad switch in the steering wheel.
Old Dec 20, 2004 | 10:31 PM
forder's Avatar
forder
is your horn working? if so, might be a broken cruise control cable, brake pedal vacuum dump valve (small plunger type device with a big vacuum line attached near the brake pedal pad arm) broken or out of adjustment. Vehicle speed sensor and/or wiring to it (mine wasn`t working because the wiring was missing!) VSS is located on the transmission. Make sure all electrical connections are CLEAN!
Old Dec 21, 2004 | 06:07 AM
Jim1995E150's Avatar
Jim1995E150
Check the other thread on cruise control from about two weeks ago or so. I had the same problem as 95 F150 on my 95 E150. Same engine as your 88, but not sure what else is similiar.
Old Dec 21, 2004 | 11:08 AM
ECONOLINITIS
I just found my thread - sorry I posted it in the wrong spot - since it was moved I haven't received notification of all your responses.
I haven't noticed a power distribution box under the hood as yet but all my fuses under the dash check out ok. How do I test the switches in the streering wheel - must I take the top apart or can I test for continuity at another point along the connection?
My horn is working and I will check to see if the control cable is broken or the vacuum line or dump valve are o.k.
Is there a seperate connection to ther VSS in the trany or does it all go through the harness?
Thanks!!
mikes econoline
21
Dec 6, 2020 04:31 PM
willow460
Feb 3, 2015 10:40 AM
racine
Dec 4, 2014 02:05 PM
BlackJeep
Nov 9, 2008 06:32 PM
walnutcreek
Mar 17, 2004 09:09 PM
