95 Ranger problem starting
Old Dec 19, 2004 | 08:53 PM
maritnry's Avatar
maritnry
Cool 95 Ranger problem starting
I have a 95 Ranger and from time to time it will not start. The motor will turn over, but will not start. I will keep trying and after 5-60 min. of trying it will start. I am not sure what the problem is, I have tested the spark when the motor would not start and there was nothing. Please help.
Old Dec 19, 2004 | 09:48 PM
el conquistador's Avatar
el conquistador
start by pulling the codes. check out the technical info thread at the top of this forum and click on pulling EEC-IV codes about halfway down. good luck.
Old Dec 19, 2004 | 11:35 PM
hreed's Avatar
hreed
The 95 Ranger was the first year that they used OBDII so you will need to get a scanner to pull the codes. If it was made between January and June, a lot of the standard code readers will not work. If it was made after June, just about any reader will pull the codes. That would be the first step, to see if the computer has set any codes. My first thought was the fuel pump relay, but if there is no spark that would rule it out. Try the codes first and keep us posted.
Old Dec 20, 2004 | 12:23 AM
el conquistador
really? i thought it was '96. sorry for the mis-information
Old Dec 20, 2004 | 01:29 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!
The EEC (electronic engine control) and fuel pump relays are known to cause intermittent no start problems. The next time it doesn't start, pop the hood and snap the EEC relay with your finger and try to start it. Those little buggers are only like $5 if you need a new one. Let us know what you find.
Old Dec 25, 2004 | 05:24 AM
Ol Rudy's Avatar
Ol Rudy
Neighbor has a 96 2.3L exhibiting similiar no start problem....has been very cold (below zero for daytime high) so I have not tried it since it failed this last time.
So...is that EEC relay in the "box" near firewall on driver's side.? If so..is that also the same box that houses the fuel relay? If not...where and what does it look like?
Old Dec 25, 2004 | 02:47 PM
el conquistador
they should be under the fuse box
Old Dec 27, 2004 | 03:10 AM
Ol Rudy's Avatar
Ol Rudy
Thanks...this is a 1996 so has fuse box with three relays within AND another box alongside...between it and fender...that has two more. Rotated all (same number). Nothing is marked of course.No manual either.
Pulling the Idleair control valve not fun...sits at rear of manifold, bolts face to firewall, wire harness in way for lower, 12 above zero. All of that and 142M miles...not plugged up as many have noted. I cleaned anyway...back on tommorrow.
giovatl
Apr 25, 2010 12:28 PM
themanrosen
Oct 18, 2007 08:41 PM
RangerPilot
Oct 4, 2007 11:08 AM
nathan3908
Jun 17, 2005 04:10 PM
susang
Jun 19, 2001 08:27 AM
