buzzing around console shifter?
Old May 12, 2007 | 09:37 AM
cullenkyla's Avatar
cullenkyla
benjitsaur I believe the noise/rattle can be fixed by taking it back to the dealer and
having the ashtray assembly change out I don't think your noise is the same as the
shifter I had mine changed and that fix the ashtray rattle
Old Dec 7, 2007 | 05:24 AM
legolamb's Avatar
legolamb
Anyone get a fix for this buzzing
Still chasing mine, dealer can never duplicate.
Old Dec 7, 2007 | 06:17 PM
moretools's Avatar
moretools
I climbed under the dash when it was making the noise. As someone else wrote, it seems to be coming from the cable that goes through the firewall (shifter cable?). Anyway, if I put my hand on it I could feel it vibrate. I pushed and pulled on the cable a little and it has stopped. So far not to return for the past few months.
Old Dec 7, 2007 | 08:59 PM
moonlighter's Avatar
moonlighter
Several years ago my wife had a chevrolet[sorry] that would make noises around dash area when ideling in gear only. I noticed while driving 1 day that the eng. was ideling lower than usual. Had it checked & it was, got emission part replaced and fixed it. With eng. ideling higher no noises.
Old Dec 8, 2007 | 06:41 PM
Ogio's Avatar
Ogio
Pull the ashtray and put felt tape where ever plastic to plastic contact occurs. You can also use the round felt stickers found at most stores for putting under lamps, etc.
Old Dec 8, 2007 | 07:57 PM
Silent Thunder's Avatar
Silent Thunder
Pull the ash tray and run a few days like that. If the noise goes away, there is your problem if not have it fumigated for bees!
1'stonraceday
18
Sep 14, 2015 08:50 AM
wasowski
Jun 2, 2015 06:02 AM
mustang_309
Apr 26, 2013 03:55 PM
K-OS
Jan 23, 2012 11:51 AM
BigMattXXL
16
Feb 11, 2004 04:11 PM
