Power steering question
Old Apr 26, 2013 | 12:48 PM
mustang_309's Avatar
mustang_309
Hey guys, I think my power steering pump is starting to go out, as it will sometimes make that whining/buzzing sound that you can hear/feel a bit in the steering wheel. But it only does this when I turn the steering wheel to the left and its not constant, it is intermittent when it does it, that is to say as I start turning left it will whine/buzz then stop and then whine/ buzz again. It wont do it until it heats up and it doesn't do it every time I turn left but it does it every time I drive it. Applying the brakes makes no difference either. I have done the power steering flush and it made no difference. Is there anything else in this power steering/hydroboost system that can cause this other than a failing pump?
Old Apr 26, 2013 | 12:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
How are your ball joints etc? If they are binding to the left it can strain the pump.
What ATF did you use for the flush?
Josh
Old Apr 26, 2013 | 01:06 PM
mustang_309
I haven't checked the ball joints, I used mercon ATF to do the flush.
Old Apr 26, 2013 | 01:11 PM
dlibson's Avatar
dlibson
I've found that a good cleaner can make a big difference when flushing. A straight flush won't clean sludge out of the valves.
Also, use a synthetic fluid.
Old Apr 26, 2013 | 01:14 PM
mustang_309
What kind of cleaner would you use? And thanks for the replies its always appreciated.
Old Apr 26, 2013 | 01:22 PM
dlibson's Avatar
dlibson
At the shop we have a specific cleaner for PS systems. Valvoline has one, Phyzix, Gunk has one. You can use the gunk trans flush stuff too if no one has the PS specific stuff.
And no problem on replies!
Old Apr 26, 2013 | 03:55 PM
smokersteve's Avatar
smokersteve
seafoam has one. I have used that once before on my durango.
1999SuperD
Sep 27, 2023 06:42 AM
Liquid10Rider
32
Jun 14, 2015 08:30 PM
pgguru
May 30, 2014 12:02 AM
boggerted
May 9, 2010 07:42 AM
wresleu
1997 - 2003 F150
Dec 3, 2007 12:03 AM
