Buzzing from underneath the dash
Old Nov 27, 2003 | 11:08 AM
BigMattXXL's Avatar
BigMattXXL
Question Buzzing from underneath the dash
Hey guys - I've got a buzzing sound coming from inside my dash. It only occurs at certain points while accelerating (from a dead stop, if I give it a little gas, for instance, when I'm accelerating to 15mph, it buzzes for a second) When it buzzes, I can feel the vibration in the gas pedal.
Any ideas?
XXL
Old Nov 27, 2003 | 07:19 PM
tyger25's Avatar
tyger25
Is there anything else on? AC?
Old Nov 27, 2003 | 09:36 PM
FTE Herman's Avatar
FTE Herman
Check the enite length of the throttle cable. I had the same thing happen. Mine was bound up and tugging against air filter.
Old Nov 27, 2003 | 09:55 PM
WillieWildcat's Avatar
WillieWildcat
Mine does the same thing at around 1500 rpm (or 40 mph). I have absolutely no idea except that you (or I) would need to tear apart the dash to find it. It is something I can live with I guess.
Old Nov 27, 2003 | 11:09 PM
BigMattXXL's Avatar
BigMattXXL
Sounds like Willie and I have the same problem - I'll check the throttle cable, see if anything's out of the ordinary.
XXL
Old Nov 28, 2003 | 10:00 AM
buzzard's Avatar
buzzard
Matt, do you hear strange voices too?
Old Nov 28, 2003 | 11:00 AM
BigMattXXL's Avatar
BigMattXXL
Talking
The voices don't want me talking to you - they say that you are the reason for all the problems, and that they're going to "take care" of you. Would you like to hang out sometime?
XXL
Old Nov 30, 2003 | 09:53 AM
buzzard's Avatar
buzzard
Sure, how about at Camp Crystal Lake?
Old Nov 30, 2003 | 01:21 PM
BigMattXXL's Avatar
BigMattXXL
Thumbs down
No can do - the voices don't like the lake - lakes are where dragons live.
XXL
Old Nov 30, 2003 | 01:22 PM
BigMattXXL's Avatar
BigMattXXL
Well, it absolutely won't buzz when it's in park, only in drive. Makes it a little more difficult to get under there and check it out .
I might go noodle with it in a few minutes.
XXL
Old Dec 2, 2003 | 07:53 PM
mechdeclined's Avatar
mechdeclined
Is it a buzzing noise like a buzzer or something else. I have noticed something in my dash too (I think left of the steering column, but haven't pinpointed it yet). Mine sounds kind of "tinny" or almost like an electrical charge or shorting sound. Not real loud, but definitely noticeable only when driving, not in park.
Old Feb 10, 2004 | 08:22 PM
mechdeclined
BigMattXXL
How loud is the buzzing sound? I am hearing one that is pretty faint when accelerating from a stop. Seems to go away or get lost with regular engine noise at about 40 mph. Service writer said she couldn't hear it. Have you pinpointed anything?
Old Feb 10, 2004 | 10:22 PM
tsdrallyer's Avatar
tsdrallyer
I can't say what your problem is, but it seems to not be the dangerous kind. A relative found a diamond back rattler was the cause of his dash buzz. A friend cranked up his '49 pickup one day and discovered the annoying buzz in his dashboard half way to work was... a hornet's nest ... and the were not very happy. He abandoned the vehicle before it even stopped in the middle of a corn patch.
Old Feb 10, 2004 | 11:36 PM
gkbid's Avatar
gkbid
Killer Bees ?
Old Feb 11, 2004 | 03:27 PM
lvmilkman2002's Avatar
lvmilkman2002
It may also be the ride leveling system....check that..up underneath where the passengers right toes would be, there is a switch to turn off the ride leveling....if you vehicle has it...check that out, if it has it, turn it off and see if the buzzing stops.
Good luck,
Milkman
