Standpipe for oil filter is broken
Just in case you didn't know. You can not put the oil cap on without a filter in. If you try to push down on it you will break the button piece at the top. I was just putting the cap on to close it up for the night until tomorrow before finishing up all the work. I fished the two pieces out. Anyone have the part number or know if that button has to be there to operate correctly?
Give these guys a call Monday.
AutoNation Ford White Bear Lake | Parts & Accessories
That search is setup for my truck. I was not able to find the part.
Also look on Ebay. I found this right off the top.
http://www.ebay.com/itm/6-0-6-4L-Powerstroke-Diesel-OEM-Genuine-Ford-Oil-Filter-Housing-Tube-F250-F350-/231266216365?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d88a69ad&vxp=mtr
Good luck.
Sean
EDIT Used the part number from Ebay 3C3Z6C755AA Price is a lot better than Ebay also Engine Oil Filter Bypass Adapter | Genuine Ford | 3C3Z-6C755-AA
Good luck.
Sean
I was able to fish the two tangs that hold it in place out of the hole. Ill take another good look and try to fit the pieces back in place to make sure they match with nothing missing. Thanks for the info on the HPOP. I am right in the middle of the reassembly after the STC, dummy plugs, and EGR block off job. I don't want to start over.
6 0 6 4L Powerstroke Diesel Genuine Ford Oil Filter Housing Tube F250 F350 | eBay
Good luck.
Sean
Good luck.
Sean
Cheers,
Rick
Thats it. Looks like I got it all out when i matched the two pieces where it broke. Needing it running tuesday at the latest so I'll hit Smith Ford or North point tomorrow. Good group working in parts at both places if your in the area. Thank you for all for the help.
