Standpipe for oil filter is broken
Old 10-18-2014, 08:34 PM
lostru's Avatar
lostru
lostru is offline
Just in case you didn't know. You can not put the oil cap on without a filter in. If you try to push down on it you will break the button piece at the top. I was just putting the cap on to close it up for the night until tomorrow before finishing up all the work. I fished the two pieces out. Anyone have the part number or know if that button has to be there to operate correctly?
Old 10-18-2014, 10:08 PM
John Irwin's Avatar
John Irwin
John Irwin is offline
The button is the filter bypass
Old 10-19-2014, 12:00 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Give these guys a call Monday.
AutoNation Ford White Bear Lake | Parts & Accessories
That search is setup for my truck. I was not able to find the part.
Also look on Ebay. I found this right off the top.
http://www.ebay.com/itm/6-0-6-4L-Powerstroke-Diesel-OEM-Genuine-Ford-Oil-Filter-Housing-Tube-F250-F350-/231266216365?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d88a69ad&vxp=mtr
Good luck.
Sean
EDIT Used the part number from Ebay 3C3Z6C755AA Price is a lot better than Ebay also Engine Oil Filter Bypass Adapter | Genuine Ford | 3C3Z-6C755-AA
Old 10-19-2014, 03:12 AM
87crewdually's Avatar
87crewdually
87crewdually is offline
The tangs from the button (bypass valve) is what took out my HPOP. Make sure you have all the pieces. I have a new tower to install but instead I put it back together carefully after oil changes. Those little tangs are fragile and I foresee it happening again.
Old 10-19-2014, 07:40 AM
bismic's Avatar
bismic
bismic is online now
Received 2,514 Likes on 1,747 Posts
Oil filter stand pipe (06) 3C3Z-6C755-AA
edit - nm - just saw that you posted it Sean!
Old 10-19-2014, 07:44 AM
lostru's Avatar
lostru
lostru is offline
I was able to fish the two tangs that hold it in place out of the hole. Ill take another good look and try to fit the pieces back in place to make sure they match with nothing missing. Thanks for the info on the HPOP. I am right in the middle of the reassembly after the STC, dummy plugs, and EGR block off job. I don't want to start over.
Old 10-19-2014, 12:51 PM
87crewdually
Here's a pic of what we're talking about.
Old 10-19-2014, 04:33 PM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
Useually when the stand pipe is broken they will hardly start and won't stay running.
Old 10-19-2014, 07:15 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is online now
6 0 6 4L Powerstroke Diesel Genuine Ford Oil Filter Housing Tube F250 F350 | eBay
Good luck.
Sean
Using that part number, it's $38.54 + shipping from Autonation Ford for a new one!!
Cheers,
Rick
Old 10-19-2014, 07:57 PM
lostru's Avatar
lostru
lostru is offline
Thats it. Looks like I got it all out when i matched the two pieces where it broke. Needing it running tuesday at the latest so I'll hit Smith Ford or North point tomorrow. Good group working in parts at both places if your in the area. Thank you for all for the help.
grassman2852
12-17-2016 06:23 PM
norman2012
11-24-2016 04:17 PM
Pest007
04-12-2016 01:55 AM
gmcbride
03-23-2015 08:49 PM
Dan Reinbold
04-07-2011 04:33 PM
Quick Reply: Standpipe for oil filter is broken
