Oil filter cap.
Old Dec 14, 2016 | 07:23 PM
grassman2852's Avatar
grassman2852
Oil filter cap.
Would y'all absolutely not buy a truck with the wrong filter cap. An 07 with only 54k miles. Or just change it immediately?
Sent from my iPhone using IB AutoGroup
Old Dec 14, 2016 | 07:42 PM
packagerjr's Avatar
packagerjr
I would have no problem purchasing if everything checks out.
​​​​​​​You can always pop the cap and at least verify a MC filter is not coupled with the tall cap.
Old Dec 14, 2016 | 09:28 PM
Yahiko's Avatar
Yahiko
No problem also, That is if all the rest checks out.
2 things I would do change back to ford filter and cap and ditch that
cold are intake thing.
How does the body look?
Sean
6.0L Tech Folder
Old Dec 14, 2016 | 09:40 PM
grassman2852
I figured about the air filter too but wasn't sure. Glad you brought that up. Body looks great to me.
Old Dec 14, 2016 | 09:42 PM
530ktmpilot's Avatar
530ktmpilot
Mine had the tall cap,and wix filter. I would pop the cap as was said above to verify they didnt use a stock MC filter to be sure all was OK.
Old Dec 14, 2016 | 10:30 PM
Yahiko's Avatar
Yahiko
I look at it this way if it used as soon as I have it home it will get an oil change.
So may as well plan on that along wit the cap and filter.
Sean
6.0L Tech Folder
Old Dec 15, 2016 | 08:29 AM
53jimc's Avatar
53jimc
I agree, check the filter to be sure it matches. That Banks air filter looks good, don't know how they perform, though.
What are the disconnected wires over there by the brake fluid reservoir? Mine has that and I always wondered what they went to.
Old Dec 15, 2016 | 08:36 AM
530ktmpilot
Probably the pre-installed wiring for upfitter switches
Old Dec 15, 2016 | 09:01 AM
TxMav's Avatar
TxMav
Take a good look at the degas cap/bottle. Looks like a little coolant around the cap. Could be nothing, but don't dismiss it. Hopefully, it's just time for a new cap.
Old Dec 15, 2016 | 10:54 AM
69cj's Avatar
69cj
Sean
6.0L Tech Folder
If I bought used with no service records, all of the fluids and filters would get changed so that I had a base number and date to start with and ALL filters would be OEM.
Old Dec 16, 2016 | 01:05 PM
grassman2852
Definitely first on the list.
Old Dec 16, 2016 | 01:30 PM
DSMMH's Avatar
DSMMH
No problem here. Just get the dealer to put the correct cap on. However, I would take it out for a test drive, get it up to OP temp and dog it. If HGs are an issue, it will puke. Check to see if ARP studs are installed. Easy to do just look at the head bolts in back of the air box. I would keep the Banks air box.
Ed
Old Dec 16, 2016 | 01:47 PM
grassman2852
Originally Posted by DSMMH
No problem here. Just get the dealer to put the correct cap on. However, I would take it out for a test drive, get it up to OP temp and dog it. If HGs are an issue, it will puke. Check to see if ARP studs are installed. Easy to do just look at the head bolts in back of the air box. I would keep the Banks air box. Ed
Mentioned the cap to the salesman and he said it's because of the lift. I just left it at that and said I'll do it myself when I get it home.
Drove it around for about 30 min. Temps stayed close to each other. Everything seemed ok.
Pretty sure no ARP studs
Old Dec 16, 2016 | 04:21 PM
Yahiko's Avatar
Yahiko
Some salesmen can be so stupid and they do anything to sell a car/truck.
Sean
6.0L Tech Folder
Old Dec 16, 2016 | 04:51 PM
87crewdually's Avatar
87crewdually
Sean
6.0L Tech Folder
Well yeah, they're salesmen. Not mechanics, and many not even auto enthusiasts. If you think that's bad go lookin at RV's. Alot of those guys never camped a night in their lives and have no clue about the product they're selling.
I would of had to say something. Probably " What the heck does the wrong cap have to do with a lift?"
