Air filter restriction gauge
Old Jun 14, 2005 | 10:05 AM
MattB_1442's Avatar
MattB_1442
I'm getting close to installing gauges, and I want to ditch the stock oil pressure, engine temp and ammeter gauges in the process.
I'm thinking 3 on the A-pillar (top to bottom) pyro, boost, engine coolant temp - and 3 on on top of the dash over the radio (L to R) oil pressure, ammeter, AND an air filter restriction gauge???. I don't need a trans temp gauge because I have a 5 speed.
I once saw a dash mounted air filter trestriction gauge over at SP Diesel's site, but no more.
Has anybody seen one available elsewhere? Or is it worth bothering with? What else would you guys put in the 6th guage position?
Old Jun 14, 2005 | 11:16 AM
Max1775's Avatar
Max1775
Don't bother with the air restriction gauge, put a decent intake on instead (Tymar, Kwik, etc). I'd still use a trans temp gauge even with a manual, if not there, I'd put a temp gauge in the rear differential. Can't ever have too much information! I have a buddy with temps for manual trans, transfer case, and both differentials and it has saved him some money over the years. Easy to see from rising temps when something is going wrong...
Max
Old Jun 14, 2005 | 12:58 PM
MattB_1442's Avatar
MattB_1442
Where do you install the temp probe in the ZF 5 speed?
Old Jun 14, 2005 | 01:07 PM
2danglong's Avatar
2danglong
Oil temp gauge a good idea. A buddy of mine used one oil temp gauge for his front and rear diff, X-fer, tranny and engine oil. he had a multi-position switch that he could select and read the temp from whatever he was concerned about..
Old Jun 14, 2005 | 03:48 PM
Max1775's Avatar
Max1775
I'd tap in to the tranny cooler lines if you have one, I'm not sure if the five speed does or not, the six speed does. If not, I'd weld a bung on the inspection plate or drill and tap the case itself (make sure it's below the fluid level and in an unobstucted area where it can't be hit by internal moving parts).
Max
Old Jun 14, 2005 | 03:51 PM
Marcus6679's Avatar
Marcus6679
You can also use a bushing to put the sender in place of where the drain plug goes. Only problem is you'll have to dump your fluid to do so.
FrankGRUN
Jun 26, 2016 12:53 PM
FrankGRUN
Electrical Systems/Wiring
Jun 25, 2016 01:01 PM
Ford_Eddie_Bauer
Jan 23, 2016 04:25 PM
rews2
19
Jul 21, 2014 07:44 PM
cadunkle
Nov 30, 2013 10:52 AM
