Spark problems
Old Dec 8, 2004 | 12:08 PM
virgward's Avatar
virgward
Spark problems
What would be the most probable cause of lack of spark 5.0. Plugs look good ,cap and rotor look fair but I don't have any spark what so ever. Any ideas?
Old Dec 8, 2004 | 12:32 PM
RR4E's Avatar
RR4E
Could be a number of things. Check the wiring to your coil, and make sure it's getting power. Check resistance on your coil to cap wire as well. Your spark control module could also be the problem.
Old Dec 8, 2004 | 07:11 PM
Lee Lichterman's Avatar
Lee Lichterman
Most likely the TFI Module on your distributor. That little grey box causes tons of ignition problems.
Buy 2 and keep a spare, they are always going bad at the worse time. Doesn't hurt to buy the little special tool that goes in there to remove it either. I had to shave a socket the first time I did one before I found out they actually make a special tool that fits in there that you can stick a dogbone on and makes it much easier.
Lee
Boodrow379
Jul 10, 2013 09:41 PM
drive03
Electrical Systems/Wiring
Sep 29, 2009 04:28 PM
llehmn
Jan 1, 2005 10:07 PM
fatherdoug
Jun 23, 2004 11:13 AM
boilersouth_2002
Jan 16, 2004 03:15 PM
