No Spark
Old Dec 31, 2004 | 10:35 AM
llehmn's Avatar
llehmn
No Spark
I have an 89 E-150 4.9 Auto. It died and it doesnt have any spark, any ideas on what to look for? With the key on both sides of the coil are hot. ????
Old Dec 31, 2004 | 07:53 PM
ACESN8S's Avatar
ACESN8S
No spark at the plug? Or no spark at the coil?
Check for spark at the coil first, then for spark from the dizzy.
When was the last time the cap and rotor were changed?
Patrick
Old Dec 31, 2004 | 07:57 PM
sixshootingexp's Avatar
sixshootingexp
try the control module, get it tested at most parts stores. check cap and rotor for carbon build up. clean connections on coil. good luck.
Old Jan 1, 2005 | 11:16 AM
llehmn's Avatar
llehmn
No spark at plug or coil. Son played the radio with the key in the on position for a few hours. Could this burn something up? Thanks.
Old Jan 1, 2005 | 04:01 PM
ACESN8S's Avatar
ACESN8S
Take the coil to a parts house, and have them test it for you.
This way you can be positive that this is your problem (or not).
Patrick
Old Jan 1, 2005 | 10:07 PM
pfogle's Avatar
pfogle
No, but if the battery is weak it could have worn it down enough to where it doesn't have the output to operate the starter and the coil at the same time. I'd start at the ignition control module. It's mounted on the dizzy body, and prone to failure from heat. Most autoparts stores now test them for free.
ymirr
Apr 6, 2017 07:42 PM
Boodrow379
Jul 10, 2013 09:41 PM
Ford Bronco Man
1978 - 1996 Big Bronco
15
Jun 3, 2011 11:19 AM
mswift
23
Jul 19, 2006 09:42 PM
virgward
Dec 8, 2004 07:11 PM
