no spark
Old Sep 22, 2009 | 05:04 PM
drive03's Avatar
drive03
no spark
coil sparked back into it self sence then i have no spark changed coile and icm from distributor changed eec relly still no spark .....
tested (-) side of coile light goes dimm dont know what to look for next????????????????????
Old Sep 22, 2009 | 06:04 PM
subford's Avatar
subford
What are you working on?
year?
engine?
transmission?
Old Sep 24, 2009 | 03:45 PM
drive03's Avatar
drive03
98 F150 with a 5.0 (302) this thing is driving me nuts
Old Sep 26, 2009 | 12:01 AM
Franklin2's Avatar
Franklin2
Check the codes in the computer. According to the info I have, a 302 was not available in that year truck.
Old Sep 26, 2009 | 06:58 AM
subford's Avatar
subford
Ok on your 1989 does the test light flash on the Neg side (-) of the coil (Tach side) while the engine cranks?
If not pull out the SPOUT jumper (shorting bar) and see if it flashes then.
If not replace the distributor or the PIP sensor (stator) inside of it.
If it does flash with the SPOUT out then you have bad wiring to the computer (shorted to ground) or a bad computer.
Old Sep 29, 2009 | 04:28 PM
drive03's Avatar
drive03
Hey i replace the distributor and what do you know the truck started right up .......
thanks for all your help hope you all have a good day ...........
ymirr
Apr 6, 2017 07:42 PM
mikecrom83
Jun 3, 2013 03:50 PM
rangergirl94
Aug 10, 2012 04:48 PM
tjs_79ford
Sep 20, 2009 11:30 AM
nick3505
1983 - 2012 Ranger & B-Series
Jul 20, 2009 10:06 AM
