89 f-250 problems
Old Dec 19, 2004 | 04:56 AM
tex94F250's Avatar
tex94F250
Well, if it's valve cover gaskets that's great. If the fuel filter was replaced without bleeding the fuel manifold (schraeder valve [looks like a tire stem valve] on fuel rail) you could have damage to your fuel regulator. Cold, it would be asking for more fuel and seem to run better, hot it doesn't need the additional fuel pressure, if it part of the problem is the regulator. The next step is the O2 sensor, fouled due to overrich condition (really rough idle) and sitting too long. If the emissions system has beentoyed with, your codes could be somewhat confused as it is designed to work as a system, one part depending on another. Check you system against a schematic under the hood. Have you purchased a manual for your truck? Everybody that is going to attempt to do anything on their own should have one. Have you used any product to break down the condensation that undoubtedly formed in the tank while it sat unused? There are several good ones on the market. The first Bronco I owned had a 302 and it did just fine after installation of a cam designed for torque and headers.
Tex
'94 F250 460 cid E4OD 4x4
Old Dec 19, 2004 | 09:31 AM
bmlawson's Avatar
bmlawson
i'm getting some injectors and regulator from my friend at work. and yes i always buy the manuels for my vehicles.
vlietracer64
Jan 19, 2009 10:39 PM
westcoastslider
Jul 13, 2008 11:40 AM
TXBDBY
Jan 19, 2005 09:05 PM
Zynryck
Sep 29, 2004 02:03 AM
remmers
Nov 30, 2003 01:02 PM
