i have a 91 f-250 351 auto 4 x 4 i just did a tune up i replaced plugs wires cap rotor new air filter (k & n) Now at idle it runs ruff but if i give it just a little gas just enought to get the revs up it runs fine, and it runs really ruff when i first start it up ( if its cold) warms up and it runs better but still ruff. is there anything i can do to correct this problem, this is my plow truck and the snow is starting to fall and i dont want to be stuck out in the middle of a storm some where and it start die on me.. thanks for any help you guys can offer
check the colant temp switch for the computer(they have one for ecm and one for guage) if it is faulty it will keep the engine in cold start mode like keeping the chocke on on a carbed engine good luck
no it shouldn't, first thing i would do is install the t-stat then see what happens, next i would check the temp switch for the ECM. I can't remember where it is at on your truck but the one next to the dist on the intake is NOT the one for the ECM. you can check the sending unit by putting an ohm meter between the plug and ground then write down the reading. Next start the truck and get it up to operating temp and check the resistance again if there is no difference in the two readings then the sender is faulty and needs to be replaced
