89 f-250 problems
Old Dec 7, 2004 | 05:02 PM
bmlawson's Avatar
bmlawson
89 f-250 problems
hi everyone,
Well here's the story. i bought my 89 f-250 custum 4x4 from my boss. to make a long story short he has had the truck since 91, and it hasn't been running since 2000. well he tells me that it needs a new motor. well i put a battery and a coil in it and she fires up. now here's the problems, first it idle's real ruff. second when you put the truck into gear it stalls and doesn't want to restart. third it needs head gaskets, is this hard to replace? and also would by-passing the air pump cause the truck to idle ruff and stall? any help would be greatly appreciated.
Old Dec 7, 2004 | 05:33 PM
andym's Avatar
andym
It sounds like the idle air valve is shot. It sits right on the throttle body, try taking it off and soaking it in carb cleaner. Before, you go throwing parts at it, though, I would pull the codes as described here: http://fordfuelinjection.com/index.php?p=13
Head gaskets are a pain. The exhaust manifold studs tend to rust and break off when you back them out. You will also need a couple special tools to get everything off. It's a big job.
Old Dec 12, 2004 | 08:47 PM
bmlawson's Avatar
bmlawson
i need more help
ok well i replaced the idle air controll valve and it helped a lot. but the truck still wants to stall when i put it in gear. i have been able to drive it but not very far because of the stalling problem. when we start it cold it idles fine. but the problems start as it warms up. it will start to foul plugs out the warmer it gets. now when i bought the truck i replaced the plugs, plug wires, cap and rotor. is there anything you guys can think of that would help me further? thanks in advance.
Old Dec 12, 2004 | 10:51 PM
Egor's Avatar
Egor
Yes, you really need to pull the codes before you spend any more money. You might have a bad intake air temp sensor which is telling the computer the engine is still cold so it keeps pouring the fuel to it. But pull the codes first.
Old Dec 16, 2004 | 12:44 PM
bmlawson's Avatar
bmlawson
alright here's the codes: 21 24 21 24 13 33 3. so what do you guys think?
Old Dec 16, 2004 | 01:22 PM
david c's Avatar
david c
what size motor do you have
Old Dec 17, 2004 | 12:27 AM
bmlawson's Avatar
bmlawson
351 windsor
Old Dec 17, 2004 | 02:09 AM
Egor's Avatar
Egor
Got my book out , it says. coolant temp sensor out of range. That's code 21. Code 24 Is Intake air charge temperature sensor out of range. The code 13 means your rpms were out of wack.
Old Dec 17, 2004 | 08:26 AM
fefarms's Avatar
fefarms
His codes are actually KOEO 21 and 24.
Continuous memory is 33
The "13" appears to be a butchery of the "1" separator pulse combined with the "3" of the first continuous memory code.
Codes 21 and 24 are probably from running the test with a cold engine. If you can get the engine to run long enough, warm it up, try again, and see if the codes go away.
Code 33 is "EGR opening not detected". Could be from messed up vacuum plumbing from the past attempt to remove emission controls. This should not have an impact on idle.
If it is fouling plugs as it warms up, it suggests to me that the oxygen sensor is telling the computer the mixture is too lean, the coolant temp sensor is stuck on always cold, the fuel pressure regulator is leaking fuel into the vacuum line, or a fuel injector is leaking. A fuel pressure test, with particular attention paid to the rate of bleed-down would be helpful here.
Old Dec 17, 2004 | 08:49 AM
jason_2674's Avatar
jason_2674
hey just a chance try fuel filter pull one off the plugs care full they get stuck good .. get back to us what they look like any manual has pic of good and bad plugs...
Old Dec 17, 2004 | 10:15 AM
bmlawson's Avatar
bmlawson
i,ll put new plugs in tomorrow morning and start it up and get the codes again. i'll put a new oxygen sensor on as well before i run the test.
Old Dec 18, 2004 | 04:48 PM
jason_2674's Avatar
jason_2674
why do u think it needs a head gasket
Old Dec 18, 2004 | 08:41 PM
tex94F250's Avatar
tex94F250
Roger that. If you truly have a head gasket problem you can have water in your cylinders, crankcase, etc. Like Jason, why the head gasket issue?
Tex
'94 F250 460 cid E4OD 4x4
Old Dec 18, 2004 | 10:11 PM
jason_2674's Avatar
jason_2674
If theirs water in your oil it will look pink and thick just a nightmere, and also i dont think head gasgets go to often on 302 but more likely the dome gasket will go
Old Dec 18, 2004 | 11:58 PM
bmlawson's Avatar
bmlawson
i was told that it needed head gaskets when i bought it. but i think it's leaking oil out of the valve cover gaskets. the fuel filter is brand new so i don't think that could be it.
