c-6 or e40d to a 5sp??
Old Dec 6, 2004 | 11:38 AM
wycowboy's Avatar
wycowboy
hey all, how hard is it to swap an auto to a stick, in a 91 IDI 4x4 f-250 excab. I think it would be the e40d , but Im not sure. when did ford switch? I was wondering if it is worth doing the switch instead of the inevitable rebuild at 160k, have any of you all ever done the swap?
Old Dec 6, 2004 | 05:58 PM
PLC7.3's Avatar
PLC7.3
If you must do the switch get a donor vehicle for all the parts under the dash and trans, clutch accessories etc.
Old Dec 19, 2004 | 10:34 AM
bigblu78's Avatar
bigblu78
I am looking to do the same swap as well.. I have an 88 F-250 Ext Cab 4x4 with the 7.3 and a C-6. I was told that the swap was very straight forward. You will need the ENTIRE clutch/brake pedal bracket as well as the safty switches, steering column, trans, driveshafts, and clutch resevoir assembly.
Old Dec 19, 2004 | 11:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck with your problems.
Enjoy FTE
801anderson
Oct 16, 2013 08:20 PM
Breaker Breaker 3-3
Aug 2, 2013 01:50 AM
mr.theman
Apr 28, 2013 10:53 AM
deisele75
17
May 10, 2005 07:30 AM
wannab4wd
Aug 11, 2001 07:32 PM
